Home » Archived » Visual Editor (VE) » Meta-Data XML or Java
Meta-Data XML or Java [message #104479] Wed, 31 August 2005 03:55 Go to next message
Originally posted by: nightblue99.yahoo.com
Hi;
Why Visual editor saves the design content in Java source file? Is
possible to use any other meta-data to save the design? and how?
Thanks;
Re: Meta-Data XML or Java [message #104569 is a reply to message #104479] Wed, 31 August 2005 17:05 Go to previous message
nightblue wrote:
> Hi;
> Thanks;
Actually VE translates the source to an EMF model by reverse parsing the code, and modeling only visual relevant items.
After the first open, VE will save a cached version of the emf model as XMI:
<Workspace>.metadata\.plugins\org.eclipse.core.resources\.projects\ <projectName>\org.eclipse.ve.java.core\.cache\emfmodel\<FileName >
You can opened it up with IE (or anything that knows how to render XML) and take a peek.
VE tries to use this cache when the file is reOpened to speed up revers parsing.
See VEModelCacheUtility.doSaveCache() of how it is saved.
Re: Meta-Data XML or Java [message #610464 is a reply to message #104479] Wed, 31 August 2005 17:05 Go to previous message
nightblue wrote:
> Hi;
> Thanks;
Previous Topic:Problem - Opening existing project - have lost design view
Next Topic:xml model adapter
Current Time: Thu Nov 20 19:43:45 EST 2025
Powered by FUDForum. Page generated in 0.03200 seconds
