Home » Eclipse Projects » Plugin Development Environment (PDE) » MANIFEST file with libraries in container
MANIFEST file with libraries in container [message #801] Fri, 11 April 2008 15:13
When I add jar files to the MANIFEST.MF > Runtime > Classpath list, they
are also added to the "Referenced Libraries" project tree node and the
..classpath project file. The problem is, I already have these jars
referenced in the .classpath file inside a libaray container, specifically
the m2eclipse org.maven.ide.eclipse.MAVEN2_CLASSPATH_CONTAINER. I've tried
to remove the maven container, and build my own user library with these jars
and I get the same results. So my question is, why does the PDE MANIFEST
file need to find jar files in the "Referenced Libraries" and why does it
ignore jar files in library containers?
Brian
Previous Topic:org.eclipse.jdt.internal.ui.text.javadoc.JavaDocCompletionProcessor
Next Topic:MANIFEST file with libraries in container
Current Time: Fri Nov 21 22:08:18 EST 2025
Powered by FUDForum. Page generated in 0.02911 seconds
