Filtering Row Data [message #104405] |
Wed, 04 January 2006 17:05  |
I have a query that returns 4 rows with a column named "code" and the
values of "alpha", "beta", "delta", and "epsilon".
I have a data field in my report such that if this column contains
"delta", I want the value of "found" to be shown in the report,
otherwise "not found" is to be displayed. The following Expression is
not working. How would I go about implementing this behavior?
if (row["code"] == "delta") {
result = "Found";
} else {
result = "Not Found";
Re: Filtering Row Data [message #104440 is a reply to message #104405] |
Wed, 04 January 2006 17:26   |
You don't need to write code to do what you want. You can use the Visibility
property.
1) Create two text elements. One text element displays "found," the other
displays "not found."
2) Set the visibility property of each element.
To hide the "found" text element, specify this expression: row["code"] !=
"delta"
To hide the "not found" text element, specify this expression: row["code"] =
"delta"
Just remember to think the opposite when specifying the expression because
you are specifying when to hide the element, rather than when to display it.
The text element is hidden when the expression is True.
"Owen Funkhouser" <eclipse@dafunks.com> wrote in message
news:dphgt1$bpp$1@utils.eclipse.org...
> result = "Found";
> } else {
Re: Filtering Row Data [message #104452 is a reply to message #104440] |
Wed, 04 January 2006 18:02   |
Thanks. I'm using BIRT v1.0 and it works opposite of what you
suggested. Is it correct to assume that this logic is reversed in v2.0?
Also, is there anyway to programmatically do this? There are some cases
where the possible values displayed are great in number or unknown until
report generation. Therefore, the text option is not a viable solution.
> property.
> "delta"
> "delta"
>> result = "Found";
>>} else {
Re: Filtering Row Data [message #104480 is a reply to message #104452] |
Wed, 04 January 2006 18:52   |
In 2.0, you specify when to hide the element. I don't remember if the
visibility logic was the reverse for 1.0.
Anyway, it is possible to do the same thing programmatically. Here's the
code I attached to a data element, and it worked:
if(row["OFFICECODE"] == "1"){
result = "Office 1";
else{
result = "No Office"
news:dphk7o$gpd$1@utils.eclipse.org...
Visibility
> > property.
other
> > "delta"
row["code"] =
> > "delta"
because
it.
> >> result = "Found";
> >>} else {
Re: Filtering Row Data [message #104630 is a reply to message #104405] |
Thu, 05 January 2006 03:27  |
Hi!
Personally i would stick to function provided by BIRT that perfectly fits
your needs. I am refering to "Map rule". Just click on your Data field in
report designer, open property browser, switch to tab Map, create a new
rule like "if row["myField"] equals "delta" then display value "found".
That's it. I believe this should work also in 1.0.1.
FUDForum. Page generated in 0.03758 seconds
