Home » Language IDEs » ServerTools (WTP) » Problems invoking code from plug-in
Problems invoking code from plug-in [message #104309] Mon, 16 May 2005 12:02 Go to next message
I just recently upgraded from Eclipse 3.1.0M6 ot 3.1.0M7, now everytime I
open Eclipse up I get lots of error messages. The majority surround
"org.eclipse.jface". The message appears as follows:
Problems occurred when invoking code from plug-in: "org.eclipse.jface"
I did some research and it looked like I needed to add the swt.jar to the
class path. I added it and still get the same message. In fact, in the
error log I get the message repeated about 10 times. I will attach the
expanded message below for additional information.
I would appreciate any guidance on resolving this issue.
Ben
java.lang.NoClassDefFoundError:
org/eclipse/core/internal/resources/mapping/ResourceMapping
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2365)
at java.lang.Class.getDeclaredMethod(Class.java:1907)
org.eclipse.ui.internal.decorators.DecoratorManager.getResou rceAdapter(DecoratorManager.java:424)
org.eclipse.ui.internal.decorators.DecoratorManager.prepareD ecoration(DecoratorManager.java:865)
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:199)
org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:1855)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:228)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:85)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1029)
at org.eclipse.core.runtime.Platform.run(Platform.java:775)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:621)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:434)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1763)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:535)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonViewer.createTreeItem(CommonViewer.java:201)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:514)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:494)
org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:983)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1201)
org.eclipse.jst.common.navigator.internal.workingset.views.C ommonWorkingSetViewer.preservingSelection(CommonWorkingSetVi ewer.java:326)
org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:973)
org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:248)
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1417)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonNavigator.createPartControl(CommonNavigator.java:170)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:310)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:185)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:559)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:26 6)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:51 4)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1064)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:552)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:489)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:485)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:230)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:781)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:2823)
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:878)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:863)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:2930)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:2928)
org.eclipse.ui.internal.PerspectiveBarContributionItem.selec t(PerspectiveBarContributionItem.java:109)
org.eclipse.ui.internal.PerspectiveBarManager$1.widgetSelect ed(PerspectiveBarManager.java:145)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2921)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2554)
org.eclipse.ui.internal.PerspectiveBarManager.handleChevron( PerspectiveBarManager.java:161)
org.eclipse.ui.internal.PerspectiveSwitcher$9.widgetSelected (PerspectiveSwitcher.java:772)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1601)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1565)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:315)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:230)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:371)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:160)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Problems invoking code from plug-in [message #104363 is a reply to message #104309] Mon, 16 May 2005 12:23 Go to previous message
Hi Ben,
The WTP project does not yet run on Eclipse M7. See the post entitled "M4
w/M7?" above.
Lawrence
Previous Topic:Ant task WSDLValidate causes ClassCastException
Next Topic:Configuring Web Services for setup with wtp-eclipse-emf-gef-jem-sdk-1.0M4.zip
Current Time: Fri Jul 25 00:45:37 EDT 2025
Powered by FUDForum. Page generated in 0.04415 seconds
