Home » Archived » Test and Performance Tools Platform (TPTP) » Automated GUI Runner Intro fails with InactiveProcessException
Automated GUI Runner Intro fails with InactiveProcessException [message #103928] Mon, 09 July 2007 17:42 Go to next message
Originally posted by: heath.junk.mail.gmail.com
I downloaded Eclipse 3.3 and the 4.4.0 TPTP runtime on Windows XP with a
Windows-IA32 4.4.0 Agent Controller running as a Windows Service.
I followed the directions on "An Introduction to Using TPTP's Automated
GUI Recorder"
( http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html),
and was unable to run the TestSuite in standard mode. It fails with an
inactive process exception.
The progress meter starts up and shows the following:
Next to the information icon, it says, "Preparing and deploying"
If I expand the details section, it has a main progress meter titled
"Launching Automated GUI Test", and subtitled "Launching: Launching
delegate...". Beneath that progress meter, there is a sub-task meter
titled "Executing Tests" and subtitled "Preparing and deploying". The
overall progress stalls at 36%.
After it fails, the following entries appear in my error log:
Entry 1:
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:422)
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2098)
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1830)
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:750)
Entry 2: IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.hyades.internal.execution.local.control .InactiveProcessException
java.lang.RuntimeException:
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.handleException(TestExecutionHarnessExecutorStub.j ava:347)
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:434)
Caused by:
... 4 more
Entry 3: IWAT4039E The Test Execution Harness reported the following
An exception stack trace is not available.
I have tried this on Eclipse 3.2.2 with TPTP Platform 4.3.1 with a
Windows-IA32 4.3.1 Agent Controller running as a Windows Service and
everything worked fine.
When using Eclipse 3.3/TPTP 4.4.0, I have verified that I have no java
processes running before I start eclipse. I have run the Agent
Controller's SampleClient and got expected output. I have also completed
the the "Setting up a TPTP test suite" section of the "Tutorial: Accessing
a datapool from a JUnit test" under the "Testing applications" section of
Eclipse Help. (I couldn't find a link to the online help for the exact
article, sorry.) I was able to run the test from the datapool tutorial on
another machine running the agent controller.
This is my feature listing:
org.eclipse.cvs (1.0.0.v20070606-7C79_79EI99g_Y9e) "Eclipse CVS Client"
org.eclipse.cvs.source (1.0.0.v20070606-7C79_79EI99g_Y9e) "Eclipse CVS
Client SDK"
org.eclipse.emf (2.3.0.v200706262000) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.0.v200706262000) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.0.v200706262000) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200706262000) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.0.v200706262000) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.3.0.v200706262000) "EMF Common"
org.eclipse.emf.common.ui (2.3.0.v200706262000) "EMF Common UI"
org.eclipse.emf.converter (2.3.0.v200706262000) "EMF Model Convert Support"
org.eclipse.emf.ecore (2.3.0.v200706262000) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200706262000) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.0.v200706262000) "Sample Ecore Editor"
org.eclipse.emf.edit (2.3.0.v200706262000) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.0.v200706262000) "EMF Edit UI"
org.eclipse.emf.mapping (2.3.0.v200706262000) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.0.v200706262000) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200706262000) "Eclipse
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.0.v200706262000) "EMF Mapping UI"
org.eclipse.equinox.source (3.3.0.v20070502-7n7LECYEOFjsvtv1NlGpLb)
"Equinox bundle source plug-in"
org.eclipse.gef (3.3.0.v20070620) "Graphical Editing Framework"
org.eclipse.jdt (3.3.0.v20070606-0010-7o7jCHEFpPoqQYvnXqejeR) "Eclipse
Java Development Tools"
org.eclipse.jdt.source (3.3.0.v20070606-0010-7o7jCHEFpPoqQYvnXqejeR)
"Eclipse Java Development Tools SDK"
org.eclipse.mylyn_feature (2.0.0.v20070627-1400) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.0.0.v20070627-1400) "Mylyn"
org.eclipse.mylyn.context_feature (2.0.0.v20070627-1400) "Mylyn"
org.eclipse.mylyn.ide_feature (2.0.0.v20070627-1400) "Mylyn"
org.eclipse.mylyn.java_feature (2.0.0.v20070628-1000) "Mylyn"
org.eclipse.mylyn.pde_feature (2.0.0.v20070627-1400) "Mylyn"
org.eclipse.pde (3.3.0.v20070607-7N7M-DUUEF6Ez0H46IcCC) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.3.0.v20070607-7N7M-DUUEF6Ez0H46IcCC) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G) "Eclipse
Platform"
org.eclipse.platform.source (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse RCP"
org.eclipse.rcp.source (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse
RCP Plug-in Developer Resources"
org.eclipse.sdk (3.3.0.v20070607-7M7J-BIolz-OcxWxvWAPSfLPqevO) "Eclipse
Project SDK"
org.eclipse.sdk.examples (3.1.200.v20070607-847XERgEE5Y56gOmWq8HKOG)
"Eclipse SDK Examples"
org.eclipse.tptp.monitoring (4.4.0.v200706132116-7c7KEFA7IYGHEGySlIWMP)
"TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.user
(4.3.100.v200706132116-774Ag0r733G3C3G3IC9) "TPTP Monitoring Project
Documentation"
org.eclipse.tptp.monitoring.examples
(4.3.100.v200706132116-328Y-w311817243227) "User examples for the TPTP
Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation
(4.3.0.v200706132116-7A79-1mA55P5K9E5MDA) "TPTP Instrumentation Monitoring
org.eclipse.tptp.monitoring.la.core
(4.4.0.v200706132116-7A78_71mA55P5M6E5855) "Monitoring Log Analyzer Core"
org.eclipse.tptp.monitoring.managedagent
(4.4.0.v200706132116-7E7D8Y2hE77Y7U8W7I8F) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.4.0.v200706132116-33--w311817241211) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx
(4.4.0.v200706132116-2-1-w311817191211) "MX4J"
org.eclipse.tptp.platform.analysis
(4.4.0.v200706132116-7E7_CE2hE77Y7Q_T8_A8) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.4.0.v200706132116-7777-0r733G3B843533) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.3.100.v200706132116-773CE0r733G3A5D3533) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core
(4.4.0.v200706132116-8Q82EN-JEPilAkZ2z0n3ku) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.3.100.v200706132116-7A6CE1mA55P5K9P5855) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.doc.user
(4.3.100.v200706132116-7A77CE08IIqQ0yIHIVKRIT_B96) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.examples
(4.3.100.v200706132116-328Y-w311817243227) "TPTP Platform Examples"
org.eclipse.tptp.platform.instrumentation.ui
(4.2.0.v200706132116-32--w311817243227) "Instrument Core UI"
org.eclipse.tptp.platform.integration.pde
(4.4.0.v200706132116-33--w311817243227) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti (4.3.0.v200706132116-7777-0r733G3E4C5549)
"TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core
(4.3.100.v200706132116-328Y-w311815251211) "Log Analysis Core"
org.eclipse.tptp.platform.lta (4.3.100.v200706132116-773Ag0r733G3C4C3533)
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit
(4.3.100.v200706132116-7E5EAU2hE77Y7NAJ9E9G) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.3.100.v200706132116-318Y-w311817171211) "Probekit User Documentation"
org.eclipse.tptp.platform.report
(4.2.100.v200706132116-7A5CE1mA55P5F9I7955) "TPTP Charting Service"
org.eclipse.tptp.platform.samples
(4.3.100.v200706132116-7A4Do1mA55P5I8F786A) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui
(4.1.300.v200706132116-772CE0r733G3C4_3533) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace
(4.3.100.v200706132116-7E7AAg2hE77Y7S9L9A8C) "TPTP Platform Trace"
org.eclipse.tptp.test (4.3.100.v200706132116-7I7ACE3cI99h9ZAT9KBC) "TPTP
Test"
org.eclipse.tptp.test.auto (4.1.100.v200705040100-773_70r733G3B8A3C76)
"TPTP Automated GUI Recording and Playback"
org.eclipse.tptp.test.doc.user (4.3.100.v200706132116-32--w311816351945)
"Test Tools User Documentation"
org.eclipse.tptp.test.samples (4.2.0.v200706132116-31--w311816151211)
"TPTP Test Samples"
org.eclipse.tptp.test.tools
(4.3.100.v200706132116-7E7C-1vNDHQ98HSBZBS8S6966) "TPTP Test Tools"
org.eclipse.tptp.test.tools.junit
(4.4.0.v200706140100-7A7A-1mA55P5L7R5855) "TPTP JUnit Plugin Test Tools"
org.eclipse.tptp.trace (4.2.0.v200706132116-771E9w0r733G3D693533) "TPTP
Trace"
org.eclipse.tptp.trace.arm (4.2.0.v200706132116-772-0r733G3E485549) "TPTP
ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.3.0.v200706132116-775-0r733G3D775549)
"Instrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.2.0.v200706132116-33--w311817243227) "TPTP
Trace JVMTI Client"
org.eclipse.xsd (2.3.0.v200706262000) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200706262000) "XML Schema Edit Framework"
Because it looks like the Automated GUI Recorder cannot be used with RCP
applications that are not the Eclipse IDE, it doesn't look like my team
will be using it. However, I wanted to alert you to this problem as it
could slow uptake of this otherwise very intriguing product.
Thanks.
Re: Automated GUI Runner Intro fails with InactiveProcessException [message #104046 is a reply to message #103928] Tue, 10 July 2007 11:46 Go to previous messageGo to next message
Thanks for reporting this issue. I am actively investigating this problem
now and will post back to this thread once we have a solution. Our biggest
problem is reproducing it on our test machines which leads me to believe it
is a specific configuration problem.
With regard to the RCP support, there is an enhancement open to address
this. Please add your self to the CC list to follow its progress:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=114159
Sincerely,
Liz Dancy
"Heath Borders" <heath.junk.mail@gmail.com> wrote in message
news:4e23fee4759e5caa1a085411c30ee721$1@www.eclipse.org...
> GUI Recorder"
> Entry 1:
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> at
> at
> at
> Caused by:
> at
> .. 4 more
> Client SDK"
> Generator"
> Generation"
> Generation UI"
> Generator UI"
> Support"
> Platform"
> Project SDK"
> "TPTP Monitoring"
> Documentation"
> Documentation"
> Documentation"
> Test"
> "TPTP Test Samples"
> Trace"
> ARM Monitoring "
> "Instrument ARM UI"
> Trace JVMTI Client"
> Thanks.
Re: Automated GUI Runner Intro fails with InactiveProcessException [message #104314 is a reply to message #104046] Wed, 11 July 2007 12:27 Go to previous messageGo to next message
Thanks very much. Do you need any other configuration information?
Re: Automated GUI Runner Intro fails with InactiveProcessException [message #104392 is a reply to message #104314] Wed, 11 July 2007 16:00 Go to previous message
Actually, it would be very helpful to know how you went about installing
TPTP and the AGR. Did you use our external download site or update manager?
Sincerely,
Liz Dancy
news:8f55f3cff92fe721fb8521a87cb15dc4$1@www.eclipse.org...
Previous Topic:Book dealing with TPTP?
Next Topic:Serialize execution traces
Current Time: Wed Nov 19 07:09:15 EST 2025
Powered by FUDForum. Page generated in 0.04932 seconds
