Home » Archived » Visual Editor (VE) » Reviewing / editing VE
Reviewing / editing VE [message #103635] Thu, 25 August 2005 14:58 Go to next message
Originally posted by: akarypid.yahoo.gr
Hi all,
I've downloaded and installed the Visual Editor SDK to review and edit the
source code. I want to do so from withing Eclipse. My "plugins" directory
indeed now has a directory called org.eclipse.ve.source_1.1.0 with several
zip files in it. Can I create a plug-in project using these as "existing
sources" or do I have to download a copy from CVS? In that case, which tag
should I checkout to get the 1.1.0 release?
Thanks.
Re: Reviewing / editing VE [message #103651 is a reply to message #103635] Thu, 25 August 2005 15:22 Go to previous messageGo to next message
Alexandros Karypidis wrote:
> Hi all,
> Thanks.
Ok, I decided to checkout R_1_1_20050722_1730 as described in:
http://www.eclipse.org/vep/WebContent/faq.html#install_cvs
While checking out I get:
cvs co -d "ve-dev-base" -P -r "R_1_1_20050722_1730" "/ve-dev-base"
cvs checkout: Updating ve-dev-base
U ve-dev-base/.classpath
U ve-dev-base/.cvsignore
U ve-dev-base/.options
U ve-dev-base/.project
[...] // stripped normal checkout messages
cvs checkout: Updating ve-dev-base/rose
U ve-dev-base/rose/.cvsignore
U ve-dev-base/rose/edocjava2.cat
U ve-dev-base/rose/instance.mdl
U ve-dev-base/rose/instantiation.cat
U ve-dev-base/rose/javaModel.mdl
cvs checkout: existing repository /home/tools/org.eclipse.jem does not
match /home/tools/org.eclipse.jem.beaninfo
cvs checkout: ignoring module org.eclipse.jem.beaninfo
match /home/tools/org.eclipse.jem.proxy
cvs checkout: ignoring module org.eclipse.jem.proxy
match /home/tools/org.eclipse.jem.workbench
cvs checkout: ignoring module org.eclipse.jem.workbench
match /home/tools/org.eclipse.ve.cde
cvs checkout: ignoring module org.eclipse.ve.cde
match /home/tools/org.eclipse.ve.java.core
cvs checkout: ignoring module org.eclipse.ve.java.core
match /home/tools/org.eclipse.ve.jfc
cvs checkout: ignoring module org.eclipse.ve.jfc
match /home/tools/org.eclipse.ve.propertysheet
cvs checkout: ignoring module org.eclipse.ve.propertysheet
match /home/tools/org.eclipse.ve.swt
cvs checkout: ignoring module org.eclipse.ve.swt
match /home/tools/org.eclipse.jem.ui
cvs checkout: ignoring module org.eclipse.jem.ui
match /home/tools/org.eclipse.jem-feature/com.ibm.etools.emf.event
cvs checkout: ignoring module ve-emf-event
match /home/tools/org.eclipse.jem.util
cvs checkout: ignoring module org.eclipse.jem.util
The server reported an error while performing the "cvs checkout" command.
(took 3:36.797)
Error: : cvs checkout: existing repository /home/tools/org.eclipse.jem
does not match /home/tools/org.eclipse.jem.beaninfo
Error: : cvs checkout: ignoring module org.eclipse.jem.beaninfo
does not match /home/tools/org.eclipse.jem.proxy
Error: : cvs checkout: ignoring module org.eclipse.jem.proxy
does not match /home/tools/org.eclipse.jem.workbench
Error: : cvs checkout: ignoring module org.eclipse.jem.workbench
does not match /home/tools/org.eclipse.ve.cde
Error: : cvs checkout: ignoring module org.eclipse.ve.cde
does not match /home/tools/org.eclipse.ve.java.core
Error: : cvs checkout: ignoring module org.eclipse.ve.java.core
does not match /home/tools/org.eclipse.ve.jfc
Error: : cvs checkout: ignoring module org.eclipse.ve.jfc
does not match /home/tools/org.eclipse.ve.propertysheet
Error: : cvs checkout: ignoring module org.eclipse.ve.propertysheet
does not match /home/tools/org.eclipse.ve.swt
Error: : cvs checkout: ignoring module org.eclipse.ve.swt
does not match /home/tools/org.eclipse.jem.ui
Error: : cvs checkout: ignoring module org.eclipse.jem.ui
does not match /home/tools/org.eclipse.jem-feature/com.ibm.etools.emf.event
Error: : cvs checkout: ignoring module ve-emf-event
does not match /home/tools/org.eclipse.jem.util
Error: : cvs checkout: ignoring module org.eclipse.jem.util
Re: Reviewing / editing VE [message #103674 is a reply to message #103651] Thu, 25 August 2005 18:20 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Use Eclipse to check it out instead of CVS command line. That way it
will be a plugin project right away for you without any extra work.
Rich Kulp
Re: Reviewing / editing VE [message #610392 is a reply to message #103635] Thu, 25 August 2005 15:22 Go to previous message
> Hi all,
> Thanks.
(took 3:36.797)
Re: Reviewing / editing VE [message #610394 is a reply to message #103651] Thu, 25 August 2005 18:20 Go to previous message
Rich Kulp
Previous Topic:Reviewing / editing VE
Next Topic:NoSuchMethodError with swt.graphics
Current Time: Wed Aug 13 12:23:35 EDT 2025
Powered by FUDForum. Page generated in 0.05767 seconds
