Home » Archived » BIRT » Eclipse, BIRT, Oracle data set exception
Eclipse, BIRT, Oracle data set exception [message #103223] Mon, 02 January 2006 15:33 Go to next message
Originally posted by: segoetz.sbcglobal.net
I have installed Eclipse 3.1.1 Win 32, and BIRT 1.0.1
Doing a tutorial, I was able to create a new report using the sample
database, Classic Models, for my data source. I can preview the data set I
created, and can see the data in the report when I preview it.
I have set up two data sources to Oracle databases and get “successful
connection” when I click “test connection”. When I set up a data set for
either and try to open it, I get the error “An unexpected internal
exception occurred. Please see log for detail.” The log says
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID rg.eclipse.birt.report.designer.ui
Version:1.0.1
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:Caused by java.lang.NullPointerException
I’ve tried to set up my paths correctly. Can anyone help? Thanks.
Re: Eclipse, BIRT, Oracle data set exception [message #117080 is a reply to message #103223] Thu, 26 January 2006 03:30 Go to previous messageGo to next message
Originally posted by: redhuanoon.yahoo.com
I do get the same HTTP Status 500 error too. Been trying all sorts of tricks
... even a blank review gives the same error.
If i do crack this, i will post here :D
Re: Eclipse, BIRT, Oracle data set exception [message #118418 is a reply to message #117080] Fri, 27 January 2006 03:16 Go to previous message
After some clue from Paul Reeves, i rechecked my extra 3rd party downloads
and notice that i misplaced the ApacheAxis' 6 files. It should be placed
exactly in
D:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib
And voila! it worked on the MySQL.
(I was trying MySQL thinking that will eliminate me that its just oracle and
not others, but MySQL had returned the same Http 500.)
So finally i tried back on Oracle (accessing Compiere DB) and it works like
magic!
Have a nice day Paul!
red1
"red1" <redhuanoon@yahoo.com> wrote in message
news:dra1b2$fcg$1@utils.eclipse.org...
>tricks .. even a blank review gives the same error.
Previous Topic:Does anyone else get this message?!
Next Topic:Engine logger
Current Time: Tue Nov 04 23:10:34 EST 2025
Powered by FUDForum. Page generated in 0.04841 seconds
