| Eclipse, BIRT, Oracle data set exception [message #103223] |
Mon, 02 January 2006 15:33  |
Originally posted by: segoetz.sbcglobal.net
I have installed Eclipse 3.1.1 Win 32, and BIRT 1.0.1
Doing a tutorial, I was able to create a new report using the sample
database, Classic Models, for my data source. I can preview the data set I
created, and can see the data in the report when I preview it.
I have set up two data sources to Oracle databases and get successful
connection when I click test connection. When I set up a data set for
either and try to open it, I get the error An unexpected internal
exception occurred. Please see log for detail. The log says
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID rg.eclipse.birt.report.designer.ui
Version:1.0.1
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:Caused by java.lang.NullPointerException
Ive tried to set up my paths correctly. Can anyone help? Thanks.
| Re: Eclipse, BIRT, Oracle data set exception [message #118418 is a reply to message #117080] |
Fri, 27 January 2006 03:16  |
Originally posted by: redhuanoon.yahoo.com
After some clue from Paul Reeves, i rechecked my extra 3rd party downloads
and notice that i misplaced the ApacheAxis' 6 files. It should be placed
exactly in
D:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib
And voila! it worked on the MySQL.
(I was trying MySQL thinking that will eliminate me that its just oracle and
not others, but MySQL had returned the same Http 500.)
So finally i tried back on Oracle (accessing Compiere DB) and it works like
magic!
Have a nice day Paul!
red1
"red1" <redhuanoon@yahoo.com> wrote in message
news:dra1b2$fcg$1@utils.eclipse.org...
>I do get the same HTTP Status 500 error too. Been trying all sorts of
>tricks .. even a blank review gives the same error.
> If i do crack this, i will post here :D
FUDForum. Page generated in 0.05535 seconds
