Home » Modeling » GMF (Graphical Modeling Framework) » java.lang.IllegalStateException: Root object of resource
java.lang.IllegalStateException: Root object of resource [message #103203] Mon, 12 February 2007 13:49 Go to next message
Originally posted by: grekier.gmail.com
Hi everyone.
I have met an error when generating the gmfgen. (The error is following)
I must say that I am lost on that one. If someone could help me please.
He uses GMF1.
!ENTRY org.eclipse.ui 4 4 2007-02-12 18:05:10.335
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2007-02-12 18:05:10.335
!MESSAGE Root object of resource
platform:/resource/test/model/o1_1a_model.gmfmap is not GenModel
!STACK 0
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$GenModelDetector.get(TransformToGenModel.java:420)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel.run(TransformToGenModel.java
:132)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at org.eclipse.jface.action.ActionContributionItem.access$2
(ActionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent (Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop (Workbench.java:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench (PlatformUI.java:149)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication
(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at sun.reflect.DelegatingMethodAccessorImpl.invoke (Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run (Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: java.lang.IllegalStateException: Root object of resource [message #103466 is a reply to message #103203] Tue, 13 February 2007 04:49 Go to previous messageGo to next message
Originally posted by: biju_gopinathan.rediffmail.com
Hi Geoffrey Rekier,
Check the following link of the gmf newsgroup
Cheers biju
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg03593.html
Geoffrey Rekier wrote:
> Hi everyone.
> He uses GMF1.
> !STACK 0
> at
> at
> :132)
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: java.lang.IllegalStateException: Root object of resource [message #103475 is a reply to message #103466] Tue, 13 February 2007 06:56 Go to previous message
Thanks for your answer but (I should have said that in the first mail) I
already tried to reload the genmodel (and the others). Even generate it
anew from .ecore. It didn't help.
biju wrote:
> Hi Geoffrey Rekier,
> Cheers biju
>> Hi everyone.
>> following) I must say that I am lost on that one. If someone could
>> help me please. He uses GMF1.
>> !STACK 0
>> at
>> at
>> :132)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Previous Topic:Creating Bend Points for a Polyline
Next Topic:Making child figure's filled inside parent figure
Current Time: Fri Nov 07 14:38:37 EST 2025
Powered by FUDForum. Page generated in 0.03508 seconds
