Home » Modeling » OCL » The generated code of OCLEcore.genmodel
The generated code of OCLEcore.genmodel [message #9392] Sun, 25 February 2007 15:09 Go to next message
The generated code out of the OCLEcore.genmodel which still has "@generated"
as its comments is the original generated code, isn't it? I mean there is no
modification upon that particular code. for example, the snipped code below
is part of the org.eclipse.ocl.ecore.CollectionTypeImpl:
* The cached value of the '{@link #getElementType() <em>Element Type</em>}'
reference.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @see #getElementType()
* @generated
* @ordered
protected EClassifier elementType = null;
I tried to regenerate the code from the given OCLEcore.genmodel from the
plugin. but the result was different, the parameter 'C' of elementType was
not generated as 'EClassifier'.
reference.
* @generated
* @ordered
protected C elementType = null;
My question is whether the part of generated code above has been modifed
manually. If not, how can I regenerate it from the given genModel to produce
the same result. Does it need to alter the option of the genModel?
Jibran
Re: The generated code of OCLEcore.genmodel [message #9417 is a reply to message #9392] Mon, 26 February 2007 09:44 Go to previous messageGo to next message
Hi, Jibran,
You are seeing the consequence of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=167935 (Multiple inheritance
with generic type bindings generates bad code).
When I generated this code, I had to find-and-replace occurrences of 'C'
with 'EClassifier', 'O' with 'EOperation', etc. because these type
parameters are not valid in the context of the subtype that binds the type
parameters of its supertype.
I did not mark the code that I changes as @generated NOT because I did not
anticipate having to regenerate until bug 167935 is fixed. Or, at least, I
don't mind making these changes when I do because it's not difficult.
Christian
A. Jibran Shidqie wrote:
> "@generated" as its comments is the original generated code, isn't it? I
> mean there is no modification upon that particular code. for example, the
> snipped code below is part of the
> Type</em>}' reference.
> * @generated
> * @ordered
> * @generated
> * @ordered
> produce the same result. Does it need to alter the option of the genModel?
> Thanks
> Best regards,
> Jibran
Re: The generated code of OCLEcore.genmodel [message #9441 is a reply to message #9417] Wed, 28 February 2007 04:14 Go to previous message
Hi Christian,
I see now. I thought there's something wrong with my EMF build.
Actually I also have asked about this problem to EMF group, and Ed suggested
me to report it to bugzilla. The problem is kind of similar that the one
you've encountered. I tried to generate it only with single inheritance, but
still the type parameter is not generated correctly.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175801
Jibran
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:erurp5$sfl$1@utils.eclipse.org...
> Hi, Jibran,
> I
> Cheers,
> Christian
>> * @generated
>> * @ordered
>> was
>> * @generated
>> * @ordered
>> genModel?
>> Thanks
>> Best regards,
>> Jibran
Previous Topic:impedance mismatch between OCL and UML2
Next Topic:allInstances
Current Time: Sat Nov 22 12:22:57 EST 2025
Powered by FUDForum. Page generated in 0.05277 seconds
