Home » Eclipse Projects » Eclipse Platform » Broken .metadata?!
Broken .metadata?! [message #102986] Wed, 30 July 2003 07:11 Go to next message
I suddenly have a problem starting Eclipse (using version 2.1.1). It
just shows a little dialog box telling "Problems during startup. Check
the ".log" file... etc.".
I have to add that I normally start it with the "-data" argument
pointing to my own workspace directory. If I start eclipse without this
arguement everything seems to be ok, so I think that the insatllation is
not broken -- despite of some strange error messages in the ".log" that
do suggest (at least for me) something different.
So some of the relevant parts of my ".log" are these:
!SESSION Jul 30, 2003 12:52:01.49
java.version=1.4.2
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -data
/home/webbasan/EWorkspace -install file:/home/webbasan/eclipse/
!ENTRY org.eclipse.core.runtime 4 2 Jul 30, 2003 12:52:01.50
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element
/Odysseus/WEB-INF/src/Document.java not found.
org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFo und(AbstractDataTree.java:243)
org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaD ataTree.java:608)
org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:54)
org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDe lta(NoDataDeltaNode.java:56)
org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:51)
org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelt a(DeltaDataTree.java:95)
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:819)
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:818)
[26 lines identical to that above deleted]
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:794)
org.eclipse.core.internal.watson.ElementTree.immutable(Eleme ntTree.java:698)
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:511)
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1033)
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1734)
org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1537)
[... many more deleted]
!ENTRY org.eclipse.core.runtime 4 2 Jul 30, 2003 12:52:01.66
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class
"org.eclipse.ui.internal.Workbench".
!STACK 0
org.eclipse.core.internal.boot.DelegatingLoaderException:
org.eclipse.core.runtime.CoreException: Problems encountered starting up
plug-in: "org.eclipse.core.res
ources".
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:754)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:185)
!ENTRY org.eclipse.core.runtime 4 2 Jul 30, 2003 12:52:01.67
!STACK 0
ources".
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jul 30, 2003 12:52:01.74
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.IllegalArgumentException: Application not found:
org.eclipse.ui.workbench.
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:856)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
So what's happening here -- and: can I fix it for myself?
And -- no, I currently don't have a backup of my workspace -- I deleted
it accidently after trying to upgrade to version 3.0M2 several days
ago... :-(
This "ObjectNotFoundException" at the beginning is irritating for me,
since that source file is actually there -- if I'm right that the path
is meant to be relative to the workspace directory.
Thanks in advance for any help or useful suggestions... ;-)
Bye,
Horst.
Re: Broken .metadata?! [message #103308 is a reply to message #102986] Wed, 30 July 2003 11:57 Go to previous message
Originally posted by: John_Arthorne.oti.com_
The workspace metadata file became corrupt. Please add a comment to bug
38682:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=38682
The most important information you can provide is what happened at the
end of your previous session. Did Eclipse crash? Was there a VM error
file? Did the session end normally? Is there any information in the log
file from the last session before the startup failure? This kind of
info can help us determine what happened, and whether this is a
duplicate of a similar bug fixed since 2.1.1.
Finally, there is some hope for your old workspace. There is a
workspace restore plugin available that will attempt to restore your old
workspace from available metadata. Download and instructions on how to
use it are found here:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/dev.html
Look under spies/tools.
Horst H.G. Weber wrote:
> java.version=1.4.2
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> ources".
> at
> at
> at
> at
> !STACK 0
> ources".
> at
> at
> at
> at
> !SESSION
> !STACK
> at
> at
> at
> ago... :-(
> Bye,
> Horst.
Previous Topic:Error In Running Eclipse IDE on LInux
Next Topic:The reason for not subclassing widgets?
Current Time: Sat Nov 08 22:49:34 EST 2025
Powered by FUDForum. Page generated in 0.03829 seconds
