| Can any body help me in Passing Parameter Code it is not working [message #102543] |
Tue, 27 December 2005 11:31 |
Following java class i have written in that
Collection params = task.getParameterDefns( false );
statemnet is not returning any thing,so params is empty so rest code is
not working.
package com.Solectron;
import java.util.Collection;
import java.util.HashMap;
import java.util.Iterator;
import java.util.Locale;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IParameterDefnBase;
import org.eclipse.birt.report.engine.api.IParameterGroupDefn;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.IScalarParameterDefn;
import org.eclipse.birt.report.engine.api.ReportEngine;
import org.eclipse.birt.report.engine.api.ReportParameterConverter;
import javax.servlet.http.HttpServletResponse;
public class Prameter {
String name="";
IReportRunnable design;
public void getReport(HttpServletResponse response,HashMap values )
EngineConfig config = new EngineConfig();
config.setEngineHome("C:/Program
Files/eclipse/plugins/org.eclipse.birt.report.viewer_1.0.1/b irt ");
System.out.println("Function openReport");
HTMLEmitterConfig hc = new HTMLEmitterConfig( );
HTMLCompleteImageHandler imageHandler = new
HTMLCompleteImageHandler( );
hc.setImageHandler( imageHandler );
config.setEmitterConfiguration(
HTMLRenderOption.OUTPUT_FORMAT_HTML, hc );
ReportEngine engine = new ReportEngine(config);
name = "First_report.rptdesign";
try{
//Create engine with configuration
design = engine.openReportDesign(name);
System.out.println("Function openReportDesign invoked");
}catch (EngineException e)
System.err.println("Report " + name + " not found!\n");
return;
if ( values.isEmpty( ) )
return;
IGetParameterDefinitionTask task =
engine.createGetParameterDefinitionTask( design );
System.out.println("default value"+task.getParameterDefn("rptuda_3"));
System.out.println("Collection Interface is Empty"+params.isEmpty());
Iterator iter = values.keySet( ).iterator( );
while ( iter.hasNext( ) )
// name is getting value that we have passed through the JSP page.
String name = (String) iter.next( );
System.out.println("Name of iter"+name);
IScalarParameterDefn found = null;
Iterator i2 = params.iterator( );
while ( i2.hasNext( ) )
System.out.println("In The Next Itteraion");
IParameterDefnBase param = (IParameterDefnBase) i2.next( );
System.out.println("Param value "+param);
if ( param instanceof IParameterGroupDefn )
continue;
if ( param.getName( ).equals( name ) )
found = (IScalarParameterDefn) param;
break;
System.out.println("Found value"+found);
if ( found == null )
System.err.println( "Parameter " + name + " not found in the
report." );
continue;
String value = (String) values.get( name );
System.out.println("value variables values"+value);
ReportParameterConverter cfgConverter = new
ReportParameterConverter( "", Locale.getDefault( ) );
Object obj = cfgConverter.parse( value, found.getDataType( ) );
values.put( name, obj );
try
String format= HTMLRenderOption.OUTPUT_FORMAT_HTML;
IRunAndRenderTask task1 = engine.createRunAndRenderTask( design );
HTMLRenderOption options = new HTMLRenderOption( );
options.setOutputFormat( format );
String output = name.replaceFirst( ".rptdesign", "." + format );
//options.setOutputFileName( output );
options.setOutputStream(response.getOutputStream());
task1.setRenderOption( options );
task1.run( );
System.out.println( "Created Report " + output + ".\n" );
catch ( Exception e1 )
System.err.println( "Report " + name + " run failed.\n" );
System.err.println( e1.toString( ) );
FUDForum. Page generated in 0.02923 seconds
