| IOException with (MAT+DTFJ) when reading a phd file [message #9334] |
Fri, 06 March 2009 13:42  |
Dear All,
I am using the IBM DTFJ adapter for Eclipse Memory Analyzer Tool to read a
IBM portable headdump file in the phd format. MAT + DTFJ i.e. the
org.eclipse.mat.parser dies with the following stack trace when reading
the phd file.
Has any one seen the parse error (pasted below) before ?
I downloaded the latest Stand-alone Eclipse RCP from
http://www.eclipse.org/mat/downloads.php
--Thanks,
Rohit
!ENTRY org.eclipse.mat.parser 4 0 2009-03-06 11:29:50.688
!MESSAGE Error opening heap dump
!SUBENTRY 1 org.eclipse.mat.parser 4 0 2009-03-06 11:29:50.688
!MESSAGE Unable to read dump
C:\pmrs\79728,005,000\79728.005.000-javacore.20090226.081020 .6940\heapdump.20090226.080944.6940.phd
metafile null in DTFJ format DTFJ-PHD
!STACK 0
java.io.IOException: Unable to read dump
org.eclipse.mat.dtfj.DTFJIndexBuilder.getDynamicDTFJDump(DTF JIndexBuilder.java:4527)
org.eclipse.mat.dtfj.DTFJIndexBuilder.getUncachedDump(DTFJIn dexBuilder.java:4274)
org.eclipse.mat.dtfj.DTFJIndexBuilder.getDump(DTFJIndexBuild er.java:4242)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:336)
org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:184)
org.eclipse.mat.parser.internal.SnapshotFactoryImpl.openSnap shot(SnapshotFactoryImpl.java:102)
org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(Snapsh otFactory.java:87)
org.eclipse.mat.ui.snapshot.ParseHeapDumpJob.run(ParseHeapDu mpJob.java:54)
Caused by: java.io.IOException: Unable to read dump
org.eclipse.mat.dtfj.DTFJIndexBuilder.getDynamicDTFJDump(DTF JIndexBuilder.java:4516)
... 8 more
Caused by: java.lang.NullPointerException
at com.ibm.dtfj.phd.PHDJavaClassLoader.remove(PHDJavaClassLoade r.java:360)
at com.ibm.dtfj.phd.PHDJavaRuntime.transferClass(PHDJavaRuntime .java:588)
at com.ibm.dtfj.phd.PHDJavaRuntime.findLoaders(PHDJavaRuntime.j ava:561)
at com.ibm.dtfj.phd.PHDJavaRuntime.<init>(PHDJavaRuntime.java:84)
at com.ibm.dtfj.phd.PHDImageProcess.<init>(PHDImageProcess.java:56)
com.ibm.dtfj.phd.PHDImageAddressSpace.<init>(PHDImageAddressSpace.java:39)
at com.ibm.dtfj.phd.PHDImage.<init>(PHDImage.java:66)
at com.ibm.dtfj.phd.PHDImage.<init>(PHDImage.java:43)
at com.ibm.dtfj.phd.PHDImageFactory.getImage(PHDImageFactory.ja va:79)
org.eclipse.mat.dtfj.DTFJIndexBuilder.getDynamicDTFJDump(DTF JIndexBuilder.java:4512)
... 8 more
FUDForum. Page generated in 0.03245 seconds
