Home » Eclipse Projects » Equinox » Jetty Post Parameters
Jetty Post Parameters [message #102227] Fri, 30 November 2007 19:27 Go to next message
Originally posted by: irbull.cs.uvic.ca
Hi all,
I have created a simple webform (hosted by a jetty server running on
equinox) and when I submit the form, I can't seem to figure out how to
get the parameters (name / value pairs).
If I get the request::getInputStream() I get content (see below), but I
thought these values should be mapped to some name value pair (like
request::getParameter(), but there are no params in my request object.
Should this be parsed for me? Or is this something I have to do myself?
This also may be my lack of understanding of servlets :-(
Ian
-----------------------------7d71b5e390850
Content-Disposition: form-data; name="textBoxFormElement"
adfadfadfad
Content-Disposition: form-data; name="listBoxFormElement"
fooValue
Content-Disposition: form-data; name="uploadFormElement";
filename="C:\Auth.prof"
Content-Type: text/plain
[PROF_MGR]
PROF_NUM=0
SEL_PROF_ID=
Re: Jetty Post Parameters [message #102241 is a reply to message #102227] Fri, 30 November 2007 22:34 Go to previous messageGo to next message
After a little more investigation, it seems that it is the content type.
If I set the encoding type to multipart then getParameters returns
nothing, but if I have it set to ENCODING_URLENCODED then the params work.
any ideas?
ian
Ian Bull wrote:
> Hi all,
> Ian
> adfadfadfad
> fooValue
> [PROF_MGR]
> PROF_NUM=0
> SEL_PROF_ID=
Re: Jetty Post Parameters [message #102254 is a reply to message #102241] Fri, 30 November 2007 23:23 Go to previous message
Ok, I have figured it out :-)
I can use:
MultiPartRequest mpr = new MultiPartRequest(req);
to parse the multipart requests.
cheers,
ian
> any ideas?
> Cheers,
> ian
> Ian Bull wrote:
>> Hi all,
>> I thought these values should be mapped to some name value pair (like
>> Thanks,
>> Ian
>> adfadfadfad
>> fooValue
>> [PROF_MGR]
>> PROF_NUM=0
>> SEL_PROF_ID=
Previous Topic:Load of JDBC driver
Next Topic:Dynamic binding of jar file delivered meanwhile runtime.
Current Time: Sun Nov 09 00:10:13 EST 2025
Powered by FUDForum. Page generated in 0.02815 seconds
