Home » Eclipse Projects » GEF » swt widgets above the editparts
swt widgets above the editparts [message #9316] Mon, 10 June 2002 10:22 Go to next message
i'd like to do something that acts like a context menu. i want to be able
to show an swt widget (Combo).
what i'm trying to do is to allow the user to select the connection tool
and then, when the user selects either the target or the source editpart,
a combo will pop-up and show the list of all the terminals.
is it possible, and if so, what are the mechanisms in GEF to allow it?
thanks
yoav
Re: swt widgets above the editparts [message #9456 is a reply to message #9316] Mon, 10 June 2002 13:29 Go to previous message
Originally posted by: none.ibm.com
Subclass one of the connecionCreationTools and override
performCreateConnection().
If you need this on both ends of the connection, you'll have to override
handleButtonPressed(int) also, and check the Tool's state.
Displaying the combo is your job ;-). You can use a Shell(SWT.NO_TRIM).
I personally thing this is a little confusing VA-Java used context menus,
with the most common terminals on the menu, and a "More..." option that
opens a dialog.
"Yoav Rubin" <yoav@il.ibm.com> wrote in message
news:ae2cni$2jr$1@rogue.oti.com...
> thanks
> yoav
Previous Topic:How to delete a figure?
Next Topic:Weird CreationTool behaviour
Current Time: Fri Nov 07 14:40:26 EST 2025
Powered by FUDForum. Page generated in 0.02874 seconds
