Home » Language IDEs » C / C++ IDE (CDT) » Save Error
Save Error [message #102206] Thu, 13 May 2004 14:01 Go to next message
Originally posted by: peter.king.galileo.com
I'm trying to use Eclipse 3.0 with CDT. When I try to save a .c file I get
the following error:
Attempted to beginRule: R/, does not match outer scope rule: L/DCC/test.c
Anyone know how to fix this?
Re: Save Error [message #102218 is a reply to message #102206] Thu, 13 May 2004 14:39 Go to previous messageGo to next message
Originally posted by: ddaoust.ca.ibm.com
Which CDT build are you using. Which Eclipse build?
There was a combination of Eclipse 3.0 M7 or M8 and CDT post M7 builds that
caused a similar problem.
- Dave
"Pete" <peter.king@galileo.com> wrote in message
news:c80d5f$d3n$1@eclipse.org...
Re: Save Error [message #103511 is a reply to message #102206] Tue, 25 May 2004 09:10 Go to previous messageGo to next message
Originally posted by: waseb.gmx.net
I have the same problem using Eclipse 3.0 M8 and CDT 2.0M8...
Re: Save Error [message #103765 is a reply to message #103511] Tue, 25 May 2004 21:01 Go to previous message
When did you download the CDT 2.0M8? I think there had been a second M8
build shortly after the announcement, because of this error.
Previous Topic:Someone must know how to install CDT??
Next Topic:Showing data in RegisterView from XML file
Current Time: Thu Jul 17 13:27:21 EDT 2025
Powered by FUDForum. Page generated in 0.06744 seconds
