Home » Archived » Memory Analyzer (MAT) » Save value to file: support specific encoding
Save value to file: support specific encoding [message #9289] Wed, 04 March 2009 14:44 Go to next message
By default (I think?) the encoding is UTF-16, which is not exactly a
common one.
It would be nice if MAT would allow me to specify the encoding (even
ASCII). Of course, if the content contains characters not supported by
some specific encoding, it should report an error and abort.
-tt
Re: Save value to file: support specific encoding [message #9381 is a reply to message #9289] Tue, 10 March 2009 05:51 Go to previous messageGo to next message
Hi Taras,
currently the logic is this (I think you mean the Save to File context
menu?):
* if only one object is selected, write the data in such a way that one
can read it via the DataInputStream (e.g. is it written as is via
DataOutputStream).
* if more than one object is selected, the string representation of the
objects is written to the text file. The output file uses the system
encoding: System.getProperty("file.encoding") Do you want a choice of
encodings here? It would only change what you need to tell your text
editor how to load the file.
Could it be that you have a byte array that contains text and we do not
convert that properly? For byte arrays we do this:
if (val >= 32 && val < 127)
result.append(val);
else
result.append("\\u").append(String.format("%04x", 0xFFFF & val));
Andreas.
Re: Save value to file: support specific encoding [message #9428 is a reply to message #9381] Tue, 10 March 2009 16:23 Go to previous messageGo to next message
Hi Andreas,
I'm saving the value of one single java.lang.String instance to a file.
Right now, the generated file uses a UTF-16 encoding, for which support
in 'common' programs/tools is kind of spotty.
I'd like to have at ASCII or UTF-8 as options:
1) UTF-8 is pretty well-supported in most editors/tools
2) ASCII is universally supported of course
In the case of ASCII, it's possible that the String instance contains
non-ASCII characters. If this is the case, I'd like MAT to notify me,
and abort.
So, in summary, my use case applies to strings only, and the main
motivator is the relatively spotty support for UTF-16.
-tt
P.S. Any chance for a new release sometime soon? :-)
Andreas Buchen wrote:
> Hi Taras,
> menu?):
> DataOutputStream).
> result.append(val);
> else
> Andreas.
Re: Save value to file: support specific encoding [message #9477 is a reply to message #9428] Thu, 12 March 2009 14:03 Go to previous messageGo to next message
The output encoding is chosen by the default coding of your platform. You
should be able to change this by adding another options:
-Dfile.encoding=UTF-8
If you add the ASCII encoding, you should get an exception.
I just say:
... new OutputStreamWriter(out, System.getProperty("file.encoding"))
But indeed I can add an option so that one can change the encoding easier
than that.
Andreas.
Re: Save value to file: support specific encoding [message #9567 is a reply to message #9477] Thu, 12 March 2009 19:59 Go to previous message
Hi Andreas,
That should provide me with a good-enough workaround for now.
I'd suggest to wait from someone else to request this as well, before
putting any effort in implementing it.
-tt
Previous Topic:Query on Heap Dump
Next Topic:can not get heap dump on win32 ?
Current Time: Thu Nov 20 11:11:08 EST 2025
Powered by FUDForum. Page generated in 0.04376 seconds
