Home » Eclipse Projects » Remote Application Platform (RAP) » Question: custom controls and text selection
Question: custom controls and text selection [message #101832] Mon, 11 August 2008 01:47 Go to next message
Gentleman,
I've made a custom control to work with text. Used some javascript to
hook a "div" with child "span" nodes.
It works as desired. However the user can't select(highlight) any text
presented by the said control.
I guess there should be a style trick to enable selection.
Re: Question: custom controls and text selection [message #102046 is a reply to message #101832] Tue, 12 August 2008 05:45 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Dmitry,
I don't know of any method of enabling text selection, I thought it
should just work as you describe. In which qooxdoo widget do you wrap
the div node? Can you provide a code snippet?
Best Regards, Ralf
Re: Question: custom controls and text selection [message #102051 is a reply to message #102046] Tue, 12 August 2008 05:51 Go to previous messageGo to next message
Ralf,
I'm using the CanvasLayout class to derive my controls.
I've already contacted folks at qooxdoo. And that's the intended
behavior, because otherwise the user can select all widgets on a page.
So I had to wrap the div node inside of iframe.
Re: Question: custom controls and text selection [message #102090 is a reply to message #102051] Tue, 12 August 2008 06:07 Go to previous messageGo to next message
Hi Dmitry,
you may want to check out the Widget#setSelectable method of qooxdoo. I
never played around with that but with a little bit luck it works as
expected.
Greets
Benny
> Ralf,
> Thanks
Re: Question: custom controls and text selection [message #102129 is a reply to message #102090] Tue, 12 August 2008 07:50 Go to previous message
Hi Benjamin,
> expected.
It does the trick. Thanks.
Previous Topic:SWT DateTime
Next Topic:How to change images?
Current Time: Fri Nov 07 03:42:54 EST 2025
Powered by FUDForum. Page generated in 0.03915 seconds
