| xerces version [message #9288] |
Wed, 08 January 2003 05:09  |
Originally posted by: Michael.Hartmeier.softwareag.com
I've seen a change from "plugins/org.apache.xerces_4_0_5 to 4_0_7 in
Eclipse 2.0.2. Does that mean you require "xerces_4_0_7" starting from
Build 20021127_0721VL?
What are the 'official' numbers for "xerces_4_0_5" and "4_0_7"?
Michael
| Re: xerces version [message #9451 is a reply to message #9383] |
Mon, 20 January 2003 10:15   |
I just checked the about.html file of the xerces plugin: it mentions that
it's based on xerces 2.0.0. (2.0.0 is what I meant with 'offical version').
I'm using XSD (build 20021023_1900TL) stand-allone, i.e. I include your
XSD jar files, the required EMF jar files and xerces jar files.
Currently, I'm using xerces 2.1 (because I simply didn't know that the
xerces plugin uses such an old version). This seems to work fine for XSD,
the only problem I found so far is simple type validation: I get
method-not-found errors because xerces APIs have changed in this area.
That's ok for me, I can avoid calling these methods (even though it would
be nice to use them ...).
Do you recommend to step back to xerces 2.0? I'd like to avoid this
because this might trigger problems in other areas of my project. I'd even
prefer to switch to xerces 2.2.1 ... Are there any plans to use a more
recent xerces version for eclipse/eclipse xsd anytime soon? Probably not
because Eclipse 2.1M4 still uses the xerces 4.0.7 plugin ...
Michael
Shane Curcuru wrote:
> Excellent question! I thought the XSD plugin would still basically work
> with the 4.0.5 version of Xerces from Eclipse, although I haven't tested it
> lately.
> I'm not sure what you mean by 'official' numbers though. As far as I can
> tell, the version numbers reported in the Xerces plugin you get with
> Eclipse builds does not correspond directly to any public Xerces builds
> from Apache, nor with any specific XML4J builds from IBM. You'd need to
> ask whoever's in charge of Eclipse's integration of Xerces to find out
> exactly what actual Xerces code from Apache is in each build in Eclipse -
> unfortunately I'm not sure who that is (although I imagine it's in the CVS
> logs).
> - Shane
> On Wed, 8 Jan 2003 10:09:16 +0000 (UTC), Michael Hartmeier
> > Michael
| Re: xerces version [message #9547 is a reply to message #9451] |
Fri, 24 January 2003 06:51  |
Michael,
I'm pretty much stuck with needing to track whatever version of Xerces is in
Eclipse and I'm not involved in the plans or decisions involving changes to that
version. If a newer version works adequately for you, that's a good thing, but
only the Eclipse Xerces version is tested and supported for XSD.
> Michael
> > lately.
> > logs).
> > - Shane
> > > Michael
Ed Merks
| Re: xerces version [message #564605 is a reply to message #9288] |
Mon, 20 January 2003 07:21  |
lately.
logs).
- Shane
> Michael
| Re: xerces version [message #564681 is a reply to message #9383] |
Michael
> lately.
> logs).
> - Shane
> > Michael
| Re: xerces version [message #564793 is a reply to message #9451] |
Michael,
> Michael
> > lately.
> > logs).
> > - Shane
> > > Michael
Ed Merks
FUDForum. Page generated in 0.05400 seconds
