Home » Archived » Visual Editor (VE) » VE stopped working in my instalation
VE stopped working in my instalation [message #101675] |
Tue, 09 August 2005 15:31  |
Originally posted by: lesliesoftware.yahoo.com
I used VE in 3.01 and recently upgraded to 3.1 and got everything working
with my previous visual classes (new workspace under 3.1 same source
code). I must say I really like the VE and am using it more and more.
After a short break from doing GUI work I went back to it yesterday and
found that of the three utility programs I am currently working on (each
is an SWT app with JFace support), One has a visual class will not load in
VE and generates a NullPointerException and a blank screen, one opens with
an error and displays as read only and the thrid works fine. I am not
sure what is wrong since I did not change GUI code since this last worked.
I did update my XML editor recently but I would hope that would be
unrelated.
I have attached .log file entries for my two failing cases and my
configuration.
Any help would be appreciated,
Ian
log from a session where I try and open the failing Visual Editor:
---8<---
!SESSION 2005-08-09 15:01:28.915
eclipse.buildId=I20050627-1435
java.version=1.5.0_04
Command-line arguments: -os win32 -ws win32 -arch x86 -data
C:\EclipseWorkspaces\WizardsFamiliar31
!ENTRY org.eclipse.core.filebuffers 4 0 2005-08-09 15:01:33.440
!MESSAGE The content type with id "org.eclipse.core.platform.text"
specified in the extension point does not exist.
!ENTRY org.eclipse.ve.java.core 4 0 2005-08-09 15:01:44.963
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.setup Control(CompositeGraphicalEditPart.java:96)
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.creat eChild(CompositeGraphicalEditPart.java:84)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:733)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:684)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:232)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:195)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:734)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:610)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:1110)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$14.run(JavaVisualEditorPart.java:2050)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ui 4 4 2005-08-09 15:01:44.978
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-08-09 15:01:44.978
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
Caused by: java.lang.NullPointerException
... 18 more
!ENTRY org.eclipse.jem.proxy 2 0 2005-08-09 15:01:45.103
!MESSAGE
+++ Warning +++: Tue Aug 09 15:01:45 EDT 2005 Project
(CardVersionFixer)-VM for CardVersionFixer:err>
org.eclipse.jem.internal.proxy.common.remote.CommandErrorExc eption--
Error code:7 Value data:"java.lang.NullPointerException:null"
org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1254)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:454)
org.eclipse.jem.internal.proxy.vm.remote.CallbackHandler.cal lbackWithParms(CallbackHandler.java:150)
org.eclipse.ve.internal.swt.targetvm.ControlManager$5.run(Co ntrolManager.java:637)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.doCallback(RemoteVMServerThread.java:541)
org.eclipse.ve.internal.swt.targetvm.ControlManager$ControlM anagerFeedbackController.run(ControlManager.java:634)
org.eclipse.ve.internal.swt.targetvm.ControlManager$1.run(Co ntrolManager.java:480)
org.eclipse.ve.internal.swt.targetvm.Environment$3.run(Envir onment.java:68)
--->8---
log from a session where I try and open the Visual Editor that results in
read only editor:
---8<---
!SESSION 2005-08-09 15:24:55.416
!ENTRY org.eclipse.core.filebuffers 4 0 2005-08-09 15:24:59.961
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-08-09 15:25:09.03
!MESSAGE
+++ Warning +++: Tue Aug 09 15:25:09 EDT 2005 Build job waiting when
trying to start beaninfo registry. Possible race.
!ENTRY org.eclipse.ve.java.core 2 0 2005-08-09 15:25:10.937
!STACK 0
java.lang.ClassNotFoundException:
org.eclipse.ve.internal.swt.TableColumnProxyAdapter
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:403)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
org.eclipse.ve.internal.cde.core.CDEPlugin.getClassFromStrin g(CDEPlugin.java:133)
org.eclipse.ve.internal.cde.core.CDEPlugin.getClassFromStrin g(CDEPlugin.java:94)
org.eclipse.ve.internal.jcm.impl.BeanDecoratorImpl.createBea nProxy(BeanDecoratorImpl.java:627)
org.eclipse.ve.internal.java.core.BeanProxyAdapterFactory.cr eateAdapter(BeanProxyAdapterFactory.java:106)
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.create Adapter(AdapterFactoryImpl.java:138)
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adaptN ew(AdapterFactoryImpl.java:112)
org.eclipse.emf.ecore.util.EcoreUtil.getRegisteredAdapter(Ec oreUtil.java:100)
org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean ProxyHost(BeanProxyUtilities.java:481)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:365)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:295)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:2041)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ve.java.core 4 0 2005-08-09 15:25:11.818
!STACK 0
java.lang.IllegalArgumentException: The feature 'control' is not a valid
feature
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenGet(BasicEO bjectImpl.java:514)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicGet(Basi cEObjectImpl.java:496)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:488)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:483)
org.eclipse.ve.internal.swt.TabItemPropertySourceAdapter.get PropertyDescriptors(TabItemPropertySourceAdapter.java:104)
org.eclipse.ve.internal.cde.properties.PropertySourceAdapter .getDescriptorForID(PropertySourceAdapter.java:53)
org.eclipse.ve.internal.swt.ItemTreeEditPart.getDirectEditTa rgetProperty(ItemTreeEditPart.java:72)
org.eclipse.ve.internal.swt.ItemTreeEditPart.createEditPolic ies(ItemTreeEditPart.java:57)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:227)
!ENTRY org.eclipse.ui 4 4 2005-08-09 15:25:11.834
!ENTRY org.eclipse.ui 4 0 2005-08-09 15:25:11.834
!MESSAGE Failed to execute runnable (java.lang.IllegalArgumentException:
The feature 'control' is not a valid feature)
!STACK 0
(java.lang.IllegalArgumentException: The feature 'control' is not a valid
feature)
Caused by: java.lang.IllegalArgumentException: The feature 'control' is
not a valid feature
... 18 more
--->8---
My configuration from Help | About:
*** Date: Tue Aug 09 15:02:07 EDT 2005
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Program Files\Eclipse31\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
978_60
-data
-vm
C:\Program Files\Java\jdk1.5.0_04\bin\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1123614088915
eclipse.vm=C:\Program Files\Java\jdk1.5.0_04\bin\javaw.exe
eclipse.vmargs=-Xmx1024M
-jar
C:\Program Files\Eclipse31\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Program Files\Eclipse31\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jdk1.5.0_04\jre\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jdk1.5.0_04\jre\lib\ext
java.home=C:\Program Files\Java\jdk1.5.0_04\jre
java.io.tmpdir=C:\DOCUME~1\ileslie\LOCALS~1\Temp\
java.library.path=C:\Program
Files\Java\jdk1.5.0_04\bin;.;C:\WINDOWS\system32;C:\WINDOWS; C:\Program
Files\Java\jdk1.5.0_02\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C:\Program
Files\cvsnt;C:\Program Files\Subversion\bin;C:\Program Files\Support
Tools\;c:\bin;C:\Program Files\SSH Communications Security\SSH Secure
Shell;C:\xindice-1.1b4\bin
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_04-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_04-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=c:\Program
Files\Eclipse31\eclipse\configuration\org.eclipse.osgi\bundl es
osgi.configuration.area=file:/c:/Program
Files/Eclipse31/eclipse/configuration/
osgi.framework=file:/c:/Program
Files/Eclipse31/eclipse/plugins/org.eclipse.osgi_3.1.0.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.0.0
osgi.install.area=file:/c:/Program Files/Eclipse31/eclipse/
osgi.instance.area=file:/C:/EclipseWorkspaces/WizardsFamilia r31/
osgi.instance.area.default=file:/C:/Documents and
Settings/ileslie/workspace/
osgi.logfile=C:\EclipseWorkspaces\WizardsFamiliar31\.metadat a\.log
osgi.manifest.cache=c:\Program
Files\Eclipse31\eclipse\configuration\org.eclipse.osgi\manif ests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\Program
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Program Files\Eclipse31\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jdk1.5.0_04\jre\lib\rt.jar;C:\Program
Files\Java\jdk1.5.0_04\jre\lib\i18n.jar;C:\Program
Files\Java\jdk1.5.0_04\jre\lib\sunrsasign.jar;C:\Program
Files\Java\jdk1.5.0_04\jre\lib\jsse.jar;C:\Program
Files\Java\jdk1.5.0_04\jre\lib\jce.jar;C:\Program
Files\Java\jdk1.5.0_04\jre\lib\charsets.jar;C:\Program
Files\Java\jdk1.5.0_04\jre\classes
sun.boot.library.path=C:\Program Files\Java\jdk1.5.0_04\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\Program Files\Eclipse31\eclipse
user.home=C:\Documents and Settings\ileslie
user.language=en
user.name=ileslie
user.timezone=America/New_York
user.variant=
*** Features:
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.0) "Eclipse Modeling Framework (EMF) Programmers
Guide"
org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.0) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.0) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.source (2.1.0) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.0) "Graphical Editing Framework"
org.eclipse.gef.examples (3.1.0) "GEF Examples"
org.eclipse.gef.sdk (3.1.0) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.1.0) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0) "Java EMF Model"
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.0) "Eclipse Platform"
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.0) "Eclipse RCP"
org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
org.eclipse.ve (1.1.0) "Visual Editor"
org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.0) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.1.0) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Active]
com.objfac.xmleditor (2.0.69) "XMLBuddy Pro" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.0) "Ant UI" [Resolved]
org.eclipse.compare (3.1.0) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.hpux (3.1.0) "hpuxFragmentName" [Installed]
org.eclipse.core.resources.linux (3.1.0) "linuxFragmentName" [Installed]
org.eclipse.core.resources.macosx (3.1.0) "macosxFragmentName" [Installed]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Active]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
org.eclipse.draw2d (3.1.0) "Draw2d" [Active]
org.eclipse.draw2d.doc.isv (3.1.0) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation"
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Active]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.1.0) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
[Resolved]
Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.1.0) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.0) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.0) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.0) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
[Resolved]
org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Active]
org.eclipse.gef.doc.isv (3.1.0) "Graphical Editing Framework
org.eclipse.gef.examples.flow (3.1.0) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.1.0) "GEF Logic Editor Example"
[Resolved]
org.eclipse.gef.examples.shapes (3.1.0) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.1.0) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.1.0) "GEF Text Editor Example" [Resolved]
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.1.0) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
org.eclipse.jdt.launching.macosx (3.1.0) "Mac OS X Launcher" [Installed]
[Resolved]
org.eclipse.jdt.source.macosx.carbon.ppc (3.1.0) "Eclipse Java Development
Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Active]
org.eclipse.jem (1.1.0) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.1.0) "Java EMF Model BeanInfo (Introspection)
Support" [Active]
org.eclipse.jem.proxy (1.1.0) "Java EMF Model Proxy Support" [Active]
org.eclipse.jem.ui (1.1.0) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.1.0) "Java EMF Model Workbench Support"
[Active]
org.eclipse.jface (3.1.0) "JFace" [Active]
org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Active]
org.eclipse.osgi.services (3.1.0) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.0) "OSGi R3 Utility Classes" [Resolved]
[Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment Runtime"
[Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.hpux.motif.PA_RISC (3.1.0) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.linux.gtk.ppc (3.1.0) "Eclipse Platform
org.eclipse.platform.source.linux.gtk.x86 (3.1.0) "Eclipse Platform
org.eclipse.platform.source.linux.gtk.x86_64 (3.1.0) "Eclipse Platform
org.eclipse.platform.source.linux.motif.x86 (3.1.0) "Eclipse Platform
org.eclipse.platform.source.macosx.carbon.ppc (3.1.0) "Eclipse Platform
org.eclipse.platform.source.win32.win32.x86 (3.1.0) "Eclipse Platform
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.aix.motif.ppc (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.hpux.motif.PA_RISC (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.linux.gtk.ppc (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.linux.gtk.x86 (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.linux.gtk.x86_64 (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.linux.motif.x86 (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.macosx.carbon.ppc (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.solaris.gtk.sparc (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.solaris.motif.sparc (3.1.0) "Eclipse RCP Plug-in
org.eclipse.rcp.source.win32.win32.x86 (3.1.0) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.0) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.carbon.macosx.ppc (3.1.0) "Standard Widget Toolkit for Mac
OS X (Carbon)" [Installed]
org.eclipse.swt.gtk.linux.ppc (3.1.0) "Standard Widget Toolkit for GTK
2.0" [Installed]
org.eclipse.swt.gtk.linux.x86 (3.1.0) "Standard Widget Toolkit for GTK
2.0" [Installed]
org.eclipse.swt.gtk.linux.x86_64 (3.1.0) "Standard Widget Toolkit for GTK
2.0" [Installed]
org.eclipse.swt.gtk.solaris.sparc (3.1.0) "Standard Widget Toolkit for GTK
2.0" [Installed]
org.eclipse.swt.motif.aix.ppc (3.1.0) "Standard Widget Toolkit for Motif"
[Installed]
org.eclipse.swt.motif.hpux.PA_RISC (3.1.0) "Standard Widget Toolkit for
Motif" [Installed]
org.eclipse.swt.motif.linux.x86 (3.1.0) "Standard Widget Toolkit for
Motif" [Installed]
org.eclipse.swt.motif.solaris.sparc (3.1.0) "Standard Widget Toolkit for
Motif" [Installed]
org.eclipse.swt.win32.win32.x86 (3.1.0) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.0) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.1.0) "Team Support UI" [Active]
org.eclipse.text (3.1.0) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.0) "Browser Support" [Resolved]
org.eclipse.ui.carbon (3.1.0) "Eclipse UI MacOS X Enhancements" [Installed]
org.eclipse.ui.cheatsheets (3.1.0) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Active]
org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.0) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.0) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework"
[Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.0) "Install/Update Core" [Resolved]
org.eclipse.update.core.linux (3.1.0) "fragmentNameLinux" [Installed]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.0) "Install/Update UI" [Resolved]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0) "Visual Editor Common Data Editor" [Active]
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.1.0) "Visual Editor Java Core" [Active]
org.eclipse.ve.jfc (1.1.0) "Visual Editor for Java Foundation Classes"
[Active]
org.eclipse.ve.propertysheet (1.1.0) "Visual Editor PropertySheet" [Active]
org.eclipse.ve.swt (1.1.0) "Visual Editor for Standard Widget Toolkit"
[Active]
org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)" [Resolved]
Guide" [Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
[Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
system.bundle (3.1.0) "OSGi System Bundle" [Active]
*** User Preferences:
#Tue Aug 09 15:02:08 EDT 2005
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.indent_parameter_description=true
@org.eclipse.ui.editors=3.1.0
@org.eclipse.debug.ui=3.1.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_at_in_annotation_type_declaration=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_enum_constant=end_of_line
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=c\:/Program
Files/Eclipse31/eclipse/plugins/org.junit_3.8.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_binary_operator=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_method_invocation_arguments=in sert
/instance/org.eclipse.jdt.ui/semanticHighlighting.parameterV ariable.color=128,128,128
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_prefix_operator=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_if=do
not insert
/instance/com.klocwork.inforcejava/enabled.errors=ABR,COV.CM P,CMP.OBJ,CMP.STR,CMPF.FLOAT,ECC.EMPTY,EHC.EQ,EHC.HASH,ESCMP .EMPTYSTR,FIN.EMPTY,FIN.NOSUPER,FSC.PRV,FSC.PUB,FSC.PRT,MNA. CAP,MNA.SUS,MNA.CNS,NPD.COND,NPD.CONST,NPD.PAR,NPDS.VAR,NPDS .EXPR,REDUN.DEF,REDUN.OP,REDUN.EQ,REDUN.EQNULL,RI.IGNOREDCAL L,RI.IGNOREDNEW,RLK.IN,RLK.OUT,RLK.IGN,RLK.SQLCON,RLK.SWT,RL K.FIELD,RNU.DEREF,RNU.THIS,RNU.NEW,RNU.NULL,RNU.NCHECK,RNU.C HECK,RR.IGNORED,RTC.CALL,STRCON.LOOP,SYNCH.NESTED,SYNCH.NEST EDS,UC.STRV,UC.STRS,UC.BOOLS,UC.BOOLB,UIR.CONSTR,UMC.EXIT,UM C.GC,UMC.SYSERR,UMC.SYSOUT,UMC.TOSTRING
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_type_arguments=insert
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_method_declaration_throws=do
not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_annotation_type_decla ration=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_bracket_in_array_allocation_exp ression=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.5
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
/instance/org.eclipse.jdt.ui/comment_format_header=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_switchstatements_compare_to_cases=true
/instance/org.eclipse.ve.java.core/PALETTE_STATE=2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_synchronized=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_question_in_conditional=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .debug.localVariable=generate
@com.objfac.xmleditor=2.0.69
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_else_statement_on_same_line=false
/instance/org.eclipse.ui.editors/printMargin=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_paren_in_parenthesized_expressi on=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.nonExternalizedStringLiteral=warning
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_for_increments=do
not insert
/instance/org.eclipse.ui.ide/quickStart=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_angle_bracket_in_parameterized _type_reference=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_multiple_field_declarations=d o
not insert
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.wizards.srcB inFoldersInNewProjects=true
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.clear_blank_lines=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_constructor_declarati on=insert
/instance/org.eclipse.jdt.ui/formatter_profile=_LeslieSoftwa re
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_conditional_expression=82
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_perspective_to_show=always
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.format_header=true
/instance/org.eclipse.ui.workbench/RECENT_FILES=10
/instance/org.eclipse.debug.ui/Expressions.detail.orientatio n=Variables.detail.orientation.right
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_angle_bracket_in_parameterized _type_reference=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_parens_in_enum_constant=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.insert_new_line_before_root_tags=insert
@org.eclipse.ui=3.1.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_compact_if=16
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.unusedLocal=preserve
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.inlineJsrBytecode=enabled
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_before_else_in_if_statement=do
not insert
/instance/org.eclipse.pde.runtime/orderValue=-1
/instance/org.eclipse.jdt.ui/semanticHighlighting.parameterV ariable.bold=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_bracket_in_array_reference=do
not insert
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant_sec_id=1112197756490
@org.eclipse.ve.cde=1.1.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.EMF_ECORE=/c\:/Program
Files/Eclipse30/eclipse/plugins/org.eclipse.emf.ecore_2.0.1/ runtime/ecore.jar
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_closing_paren_in_cast=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_explicitconstructorcall_argum ents=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_annotation_type_declaration=end_of_line
/instance/org.eclipse.update.ui/ConfigurationView.showUnconf =true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_constructor_declarati on=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_bracket_in_array_allocation_ex pression=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_for=insert
/instance/com.klocwork.inforcejava/license.server.host=flex1 .klocwork.com
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_array_initializer=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_conditional=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_CORE_RESOURCES=/c\:/Program
Files/Eclipse30/eclipse/plugins/org.eclipse.core.resources_3 .0.0/resources.jar
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_parameters_in_constructor_declaration=18
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_between_type_declarations=2
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_multiple_field_declarations=in sert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_arguments_in_explicit_constructor_call=18
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_braces_in_array_initializer=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_catch=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_in_empty_enum_declaration=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_switchstatements_compare_to_switch=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_package=0
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.jdt.ui/code_assist_preferences_last_op en=Advanced
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_method_declaration_parameters =do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_member_type=2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_at_in_annotation=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_assignment_operator=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_in_empty_method_body=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_annotation_type_membe r_declaration=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_empty_array_initializer_on_one_line=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_ellipsis=insert
/project/OracleCardRetriever/org.eclipse.core.resources/enco ding//src/com/lesliesoftware/oraclecardretriever/messages.pr operties=8859_1
@org.eclipse.jdt.debug.ui=3.1.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.tabulation.char=space
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_array_initializer=end_of_line
/instance/org.eclipse.jdt.ui/comment_new_line_for_parameter= false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.align_type_members_on_columns=false
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant=org.eclipse.team.cvs.ui.cvsworkspace- participant
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_postfix_operator=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_parens_in_method_declaration=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_arguments_in_method_invocation=18
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_default=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_block_in_case=end_of_line
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_block=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_switch=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_closing_brace_in_block=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_allocation_expression=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_annotation=insert
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=113
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_field=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_parens_in_annotation_type_membe r_declaration=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_imple_if_on_one_line=false
/instance/com.klocwork.inforcejava/check.fp.filter=false
/instance/org.eclipse.pde.core/saved_platform0=c\:\\Program
Files\\Eclipse30\\eclipse
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_angle_bracket_in_type_paramete rs=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.KW_HOME=W\:/KW
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_block=end_of_line
/instance/org.eclipse.gef.examples.shapes/ShapesEditorPalett eFactory.Size=125
/instance/org.eclipse.jdt.ui/formatter_settings_version=8
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.continuation_indentation_for_array_initializer=2
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_p erspective_on_suspend=always
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_in_empty_block=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
@org.eclipse.team.cvs.ui=3.1.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.5
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_imports=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_selector_in_method_invocation=16
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_angle_bracket_in_type_paramete rs=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=c\:/Program
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_bracket_in_array_reference=do
not insert
/instance/org.eclipse.jdt.ui/semanticHighlighting.localVaria bleDeclaration.italic=true
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?
Re: VE stopped working in my instalation [message #610205 is a reply to message #101688] |
Tue, 09 August 2005 16:09  |
Rich Kulp wrote:
> You need to upgrade to VE 1.1 to work with Eclipse 3.1. VE 1.1 is
> available from the Eclipse update site.
I do have VE 1.1 installed. My about box shows it and from my
configuration attached to my previous message:
*** Features:
Running with -clean did not change anything either.
Ian
Re: VE stopped working in my instalation [message #610208 is a reply to message #101696] |
Tue, 09 August 2005 17:58  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
But is it the final released 1.1?
If it is, then open one VE editor, and close it. Let the failure occur.
Then do Project->Clean...->Clean ALL projects. Then try it again.
The first set of errors should be impossible. I don't see how an NPE
could occur there. The second one tells me you have a bad cache, the
clean all should handle that.
Rich Kulp
Re: VE stopped working in my instalation [message #610214 is a reply to message #101721] |
Wed, 10 August 2005 06:18  |
<snip>
I intended to downloaded the final build. The plug-in files are dated
2005-07-22 1721 in my VE instalation.
Performing the project clean did not change anything.
I reallize one other thing that is common between the two visual editors
that will not open - both classes add a menu to the window. When I
origonally added the menu I had to do it by hand and it was ignored by the
visual editor.
Thanks for your help,
Ian
Re: VE stopped working in my instalation [message #610216 is a reply to message #101779] |
Wed, 10 August 2005 06:25  |
Ian Leslie wrote:
<snip>
> visual editor.
<snip>
I commented out the menu creation code for both cases and the data members
and VE work again for that class. Putting the menu code back in caused
the same error again.
Ian
Re: VE stopped working in my instalation [message #610233 is a reply to message #101785] |
Wed, 10 August 2005 13:15  |
Please open a bugzilla and attach as a file a copy of one of the classes
that fails. We can see what's going on and try not not barf.
> members and VE work again for that class. Putting the menu code back in
> caused the same error again.
> Ian
Rich Kulp
Current Time: Mon Jul 21 21:34:56 EDT 2025
Powered by FUDForum. Page generated in 0.05959 seconds
