Home » Archived » Test and Performance Tools Platform (TPTP) » Slow profiling
Slow profiling [message #101649] Mon, 25 June 2007 11:15 Go to next message
Originally posted by: ffanton.ibc.it
Hi everyone!
I'm sorry, I'm having sluggish performance when profiling with TPTP 4.2, and by "sluggish" I mean that a 2-seconds method takes about 50s when profiled..
I'm monitoring just execution times, and I filtered the monitored classes to the bare minimum.. Any idea of what could be the culprit? :/
My specs:
- Linux (Fedora 6) kernel 2.6.20
- Eclipse 3.2.2
- TPTP 4.2 (from Callisto website via Update Manager)
- Agent controller 4.3.0
I'm trying to profile a local class, which uses Hibernate for persistence.
Many thanks in advance, please ask if you need more information!
Re: Slow profiling [message #101668 is a reply to message #101649] Tue, 26 June 2007 02:39 Go to previous messageGo to next message
Federico Fanton wrote:
> Hi everyone!
> My specs:
> - Eclipse 3.2.2
Federico,
The new JVMTI Profiler in TPTP 4.4 will probably work faster in your
case. The main reason is that only monitored classes (i.e., classes
which pass the filter criteria) are instrumented and the rest of the
application (including the Hibernate framework) runs at full speed.
To use the new profiler, you'll need Eclipse 3.3. Please check the TPTP
4.4 download page for the exact prerequisites.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Slow profiling [message #101678 is a reply to message #101668] Tue, 26 June 2007 05:24 Go to previous messageGo to next message
On Tue, 26 Jun 2007 09:39:51 +0300
Sounds good :)
Anyway I'm puzzled by this "sudden" slowness, I've used TPTP in the past and it was much faster.. (Same VM - Sun 1.5 - but I can't remember Eclipse/TPTP versions :/ )
I'll try that, many thanks for your help!
Re: Slow profiling [message #101766 is a reply to message #101678] Tue, 26 June 2007 10:58 Go to previous messageGo to next message
On Tue, 26 Jun 2007 11:24:19 +0200
I downloaded the all-in-one package (stable build) and Eclipse 3.3RC4, now when I try to profile my application (using the IAC) I get
"Error occurred during initialization of VM
Could not find agent library on the library path or in the local directory: JPIBootLoader"
I double-checked the installation instructions, but I can't figure out what's wrong.. :( Maybe I'm missing some LD_LIBRARY_PRELOAD magic?
Re: Slow profiling [message #101781 is a reply to message #101766] Tue, 26 June 2007 11:30 Go to previous messageGo to next message
On Tue, 26 Jun 2007 16:58:58 +0200
Found it!
I added
LD_LIBRARY_PRELOAD=/opt/eclipse/plugins/org.eclipse.tptp.pla tform.jvmti.runtime_4.4.0.v200705041104/agent_files/linux_ia 32
to my Eclipse script, and installed the "New Java Profiler" plugin..
Everything is much smoother now, great :)
Re: Slow profiling [message #101791 is a reply to message #101781] Tue, 26 June 2007 11:32 Go to previous message
On Tue, 26 Jun 2007 17:30:09 +0200
Whoops, that's LD_LIBRARY_PATH of course, sorry ^^;
Previous Topic:Understanding the Execution Statistics view, Method Invocation panel
Next Topic:Problem getting started with the new TPTP version
Current Time: Thu Nov 06 13:59:02 EST 2025
Powered by FUDForum. Page generated in 0.03915 seconds
