Home » Archived » XML Schema Definition (XSD) » prohibiting attributes in extension
prohibiting attributes in extension [message #9265] Wed, 08 January 2003 05:02 Go to next message
Originally posted by: Michael.Hartmeier.softwareag.com
Eclipse allows to create a schema where a derived type prohibites an
attribute of the base type. Is this correct, is the attached schema valid
according the the XML schema spec? I'd expect to see some kind of XSD
diagnostics, but there are none (with XSD 20021023_1900TL).
Michael
<xs:schema xmlns:xs='http://www.w3.org/2001/XMLSchema'>
<xs:complexType name='base'>
<xs:sequence>
<xs:element name='a' type='xs:string'/>
</xs:sequence>
<xs:attribute name='a' type='xs:string' use='required'/>
<xs:attribute name='b' type='xs:string' use='required'/>
</xs:complexType>
<xs:complexType name='derived' >
<xs:complexContent>
<xs:extension base='base'>
<xs:sequence>
<xs:element name='b' type='xs:string'/>
</xs:sequence>
<xs:attribute name='b' type='xs:string' use='prohibited'/>
<xs:attribute name='c' type='xs:string' use='required'/>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:schema>
Re: prohibiting attributes in extension [message #9522 is a reply to message #9265] Fri, 24 January 2003 06:45 Go to previous messageGo to next message
Michael,
No, this schema is not correct. It violates cause 1.2 of cos-ct-extends,
i.e., the base type's attributes uses are not a subset of those of the
complex type itself. (Only a restriction can prohibit attributes.) I've
fixed the implementation to produce a diagnostic for this case.
Thanks for finding this problem.
> Michael
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
Ed Merks
Re: prohibiting attributes in extension [message #11707 is a reply to message #9522] Sat, 01 March 2003 04:51 Go to previous message
Build 1207 properly reports the invalid schema :-)
Michael
Ed Merks wrote:
> Michael,
> > Michael
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:schema>
> Ed Merks
Re: prohibiting attributes in extension [message #564765 is a reply to message #9265] Fri, 24 January 2003 06:45 Go to previous message
Michael,
> Michael
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
Ed Merks
Re: prohibiting attributes in extension [message #565472 is a reply to message #9522] Sat, 01 March 2003 04:51 Go to previous message
Michael
Ed Merks wrote:
> Michael,
> > Michael
> > <xs:sequence>
> > </xs:sequence>
> > </xs:complexType>
> > <xs:complexContent>
> > <xs:sequence>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > </xs:schema>
> Ed Merks
Previous Topic:restricting attributes
Next Topic:"xmlns" in the <schema> element
Current Time: Sun Jul 27 22:19:29 EDT 2025
Powered by FUDForum. Page generated in 0.03604 seconds
