| Parser not recognize symbols defined in another file [message #101449] |
Tue, 04 May 2004 20:08   |
Eclipse User  |
Originally posted by: ae8h-kry.asahi-net.or.jp
I use Eclipse 3.0M8 and CDT2.0.200405040300 on Windows XP and cvgwin.
I'm trying to use the wxWigets C++ GUI Toolkit on CDT.
One of the header files in wxWidgets has the following line:
    class WXDLLEXPORT wxCaret;
and in another file, there is
    #define WXDLLEXPORT
But the CDT parser recognizes wxCaret as 'class WXDLLEXPORT' variable,
not class declaration.
Why I say such a thing?
This confuses the CDT parser and makes Code Assist less useful.
I avoid this parser confusion by setting 'WXDLLEXPORT' as 'Defined symbols'
in the project property.
I think this is an ad hoc solution.
Does anybody know how I should do?
And does the CDT Team have a plan to handle this problem?
Thank you.
Hideki Kariya
| Re: Parser not recognize symbols defined in another file [message #101757 is a reply to message #101749] |
Fri, 07 May 2004 12:19    |
Eclipse User  |
Sorry, maybe updating of CDT has nothing to do with the problem solution.
I forgot setting "WXDLLEXPORT". This ad hoc way makes Code Assist work.
"kariya" <ae8h-kry@asahi-net.or.jp> wrote in message
news:c7gafk$hfj$1@eclipse.org...
> Updating CDT to 2.0.200405060300 solved my problem posted above.
> Code Assist works pretty well,
> but some symbols such as  'wxBLACK' is not displayed in Code Assist
> candidates
> though 'wxBLACK' and other symbols are displayed in the Outline panel.
> (The header file that defines the symbols is included.)
> I'll check what is happening further.
> Thank you.
> Hideki Kariya
> "johnc" <jcamelon@ca.ibm.com> wrote in message
> news:c7g35o$6d9$1@eclipse.org...
> > The Outline View/CModel does not recognize wxCaret as a foreward
> declaration
> > of a class; however, the indexer and content assist should.
> > Assuming your include paths and preprocessor definitions are set up
> > properly, and the file that ocntains the wxCaret definition is included,
> you
> > should see it come up in Content Assist.
> > If not, please raise a defect @ bugs.eclipse.org and I'll take a look at
> it.
> > Thanks
> > JohnC
> > news:c79atr$gkm$1@eclipse.org...
> > > Hello,
> > >     #define WXDLLEXPORT
> > symbols'
> > > Thank you.
> > > Hideki Kariya
| Re: Code Assist successful [message #101990 is a reply to message #101840] |
Tue, 11 May 2004 11:53   |
Eclipse User  |
No worries!
Feel free to raise defects on any behaviour that you feel is incorrect in
content assist.
news:c7jn6j$k4s$1@eclipse.org...
> Hello,
> Sorry. I didn't see the message "Code Assist has timed out".
> I tried to set the value of "Contnent Assist parsing timeout" to the
> maximum,
> and Code Assist seems to work well without any configuration such as
> 'Defined symbols'.
> I hava to apologize to say irrelevant things.
> Thank you.
> Hideki Kariya
> declaration
> you
> it.
> > Thanks
> > JohnC
FUDForum. Page generated in 0.04230 seconds
