Home » Language IDEs » Java Development Tools (JDT) » How JavaEditor example can extend CompilationUnitEditor
How JavaEditor example can extend CompilationUnitEditor [message #9236] Wed, 30 April 2003 10:11 Go to next message
Hi all,
I am using the javaeditor example to test my plugin work.I am trying to
get hold of ISourceViewer through the following methodby pressing a button
on the messageDialog after teh editor has been created.
public void setEditable(boolean editable) {
ISourceViewer viewer = getSourceViewer();
if (viewer != null) {
viewer.setEditable(editable);
But I am having some difficulty as I always get a null value for
"viewer".I read a hack for this problem that is:
if (part instanceof CompilationUnitEditor) {
CompilationUnitEditor editor = (CompilationUnitEditor)part;
ITextViewer viewer =
(ITextViewer)editor.getAdapter(ITextOperationTarget.class);
I get "part" from this code
IEditorPart part = page.getActiveEditor();
System.out.println("part");
The "part" value I get here says
org.eclipse.internal.jdt.ui.javaeditor.compilationuniteditor .
But my editor extends TextEditor not CompilatioUunitEditor,because of
which the code doesn't run.If I change it to "part instanceof TextEditor"
it won't work as the part value is different.
On the other hand if I try to extends the javaeditor from
CompilationUnitEditor I can't do that as I get an error "can't resolve it".
Any help would be appreciated.
Syed
Re: How JavaEditor example can extend CompilationUnitEditor [message #11021 is a reply to message #9236] Thu, 01 May 2003 13:24 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
It can't. This is telling you that the active editor in the page is the
standard Java editor, not your editor.
Bob
"Syed Rizvi" <sma_r@hotmail.com> wrote in message
news:b8olih$2g4$1@rogue.oti.com...
> Hi all,
it".
> Syed
Re: How JavaEditor example can extend CompilationUnitEditor [message #11639 is a reply to message #11021] Thu, 01 May 2003 23:46 Go to previous messageGo to next message
:-( That is weird sort of,I have been working with that editor for such a
long time knowing that it is my editor.Is there any way I can cjheck if my
editor is really working as it is suppose to.
Syed
> Bob
> > Hi all,
> it".
> > Syed
Re: How JavaEditor example can extend CompilationUnitEditor [message #12342 is a reply to message #11639] Fri, 02 May 2003 11:16 Go to previous message
You can always set a breakpoint in your editor. If the debugger stops there,
your editor is running. (But I thought part of your problem was that
breakpoints are mysteriously not being hit?)
Bob
news:b8splr$1gv$1@rogue.oti.com...
> Syed
> > Bob
> > > Hi all,
to
button
TextEditor"
> > it".
> > > Syed
Previous Topic:Upgrade from Eclipse 2.0 to 2.1 loses JUnit
Next Topic:How to make Ant errors/warnings appear in Tasks?
Current Time: Mon Jul 21 20:03:21 EDT 2025
Powered by FUDForum. Page generated in 0.04376 seconds
