Home » Archived » M2M (model-to-model transformation) » [QVTO] UML Primitive Types
[QVTO] UML Primitive Types [message #100804] Thu, 26 February 2009 08:05 Go to next message
Originally posted by: loic.fejoz.realtimeatwork.com
It seems that the few explanations on the forum is not enough for me.
I try a simple Uml2Uml transformation that add accessors. But I also add
an accessors that tell if an attribute has already been set (for 0..1
attributes).
What I have understand so far is that I need to add a pseudo input that
will reference the UMLPrimitiveTypes library. My code thus begin with:
transformation Model2JavaImpl(in uml : UML, in umlPrimitiveTypes : UML,
out UML);
modeltype UML uses 'http://www.eclipse.org/uml2/2.1.0/UML';
Later I would like to create an operation whose return type is Boolean.
I get stuck on the return type.
On launch, uml is my input model, umlPrimitiveTypes is set to
pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml.
But it does not work. I do not find how to get the
UMLPrimitiveTypes::Boolean!
Any thoughts or links?
Loïc Fejoz
Re: [QVTO] UML Primitive Types [message #100818 is a reply to message #100804] Thu, 26 February 2009 10:56 Go to previous messageGo to next message
Hi Loïc,
The code snippet bellow shows an example how to resolve UML primitive
types.
/Radek
transformation Test(in eModel : ECORE, out umlModel : UML, in
primitiveTypes : UML);
main() {
object UML::Model {
ownedType += object UML::Class {
ownedOperation += object Operation@umlModel {
ownedParameter += object UML::Parameter {
type := getPrimitiveType("Boolean");
query getPrimitiveType(typeName : String) : UML::PrimitiveType {
var primitives :=
primitiveTypes.rootObjects()[Model].ownedElement[UML::Primit iveType];
return primitives![name = typeName];
On Thu, 26 Feb 2009 14:05:32 +0100, Loïc Fejoz
<loic.fejoz@realtimeatwork.com> wrote:
> attributes).
> out UML);
Re: [QVTO] UML Primitive Types [message #100831 is a reply to message #100818] Fri, 27 February 2009 03:11 Go to previous message
Many thanks!
Much more simple than all the expressions I have tried and... working!
I really think, there should have a simple example on the wiki for
Uml2Uml transformation with clone, deepclone and PrimitiveTypes...
Indeed it seems trivial while reading but discovering it (and getting it
correct) is not!
Thanks again,
Loïc Fejoz
Radek Dvorak a écrit :
> Hi Loïc,
> types.
> /Radek
> main() {
> object UML::Model {
> var primitives :=
>> add an accessors that tell if an attribute has already been set (for
>> 0..1 attributes).
>> that will reference the UMLPrimitiveTypes library. My code thus begin
>> with:
>> UML, out UML);
>> Boolean. I get stuck on the return type.
Previous Topic:[ATL] Where can we find the ATL 3.0 metamodel?
Next Topic:[ATL] assignment does not work
Current Time: Tue Jul 22 02:39:58 EDT 2025
Powered by FUDForum. Page generated in 1.21648 seconds
