Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [JET] Switching on eClass()
[JET] Switching on eClass() [message #100774] Tue, 06 November 2007 01:35 Go to next message
I am trying to use EMF JET to traverse an EMF model. I am able to access the
members of the model, but I need the equivalent of the EMF Switch utility
class to distinguish instances of subclasses. I would like to use the
built-in XPath functions, if possible.
Concrete case: I have a Script metaclass, which has an eReference to a Steps
Metaclass, that are of different subtypes. I have to produce different
output for each case. How can I write this in EMF JET?
What is the test predicate of the conditional?
<c:when test="value">
content to process if tag condition is satisfied
</c:when>
Re: [JET] Switching on eClass() [message #100826 is a reply to message #100774] Tue, 06 November 2007 07:27 Go to previous messageGo to next message
Jörn,
I'll redirect your JET question to the M2T newsgroup which I've added to
the "to" list of the reply.
> </c:when>
Re: [JET] Switching on eClass() [message #100853 is a reply to message #100826] Tue, 06 November 2007 09:10 Go to previous messageGo to next message
J
Re: [JET] Switching on eClass() [message #100965 is a reply to message #100853] Tue, 06 November 2007 23:21 Go to previous message
Paul,
Yes that helped. I know XPath pretty well, just the mapping is a bit
difficult. I have put an entry on the JET FAQ/Wiki, at
http://wiki.eclipse.org/JET_FAQ_How_do_I_test_for_the_type/E Class_of_an_element_in_XPath%3F
but your explanation is much richer.
Maybe you want to update the entry?
Thanks for the information!!
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:fgpsn1$chq$1@build.eclipse.org...
> J
Re: [JET] Switching on eClass() [message #610238 is a reply to message #100774] Tue, 06 November 2007 07:27 Go to previous message
Jörn,
> </c:when>
Re: [JET] Switching on eClass() [message #610242 is a reply to message #100826] Tue, 06 November 2007 09:10 Go to previous message
J
Re: [JET] Switching on eClass() [message #610258 is a reply to message #100853] Tue, 06 November 2007 23:21 Go to previous message
Paul,
> J
Previous Topic:UMLProfile vs Ecore
Next Topic:[CDO] No client notifications when changes saved
Current Time: Fri Jul 18 00:26:22 EDT 2025
Powered by FUDForum. Page generated in 0.49386 seconds
