Home » Archived » BIRT » Bar chart with 7 categories and 4 values
Bar chart with 7 categories and 4 values [message #100758] Tue, 20 December 2005 07:41 Go to next message
Originally posted by: prooteus_NOSPAM.gmx.net
I have here some data that consists of 7 categories (names) and each
category has 4 values (added, deleted, unchanged and ratio).
When I render the bar chart programmatically, the following stacktrace
is produced:
org.eclipse.birt.chart.exception.ChartException: Horizontal axis
contains 7 objects; vertical axis contains 4 objects
org.eclipse.birt.chart.render.BaseRenderer.validateDataSetCo unt(BaseRenderer.java:2100)
at org.eclipse.birt.chart.render.Bar.renderSeries(Bar.java:93)
org.eclipse.birt.chart.render.AxesRenderer.renderPlot(AxesRe nderer.java:1196)
org.eclipse.birt.chart.render.AxesRenderer.render(AxesRender er.java:330)
at org.eclipse.birt.chart.factory.Generator.render(Generator.ja va:522)
I have the following code here:
for (int i = 0; i < data.length; i++) {
double [] values = new double[data[i].length];
for (int j = 0; j < data[i].length; j++) {
values[j] = data[i][j];
NumberDataSet orthoValues = NumberDataSetImpl.create(values);
// Y-Series
BarSeries barSeries = (BarSeries) BarSeriesImpl.create();
//barSeries.setSeriesIdentifier(series[i]);
barSeries.setSeriesIdentifier("Test");
barSeries.setDataSet(orthoValues);
data is a 2-dim double-array [7][4] and the categories are a list of 7
strings.
What must I do to get this running?
Stefan
Re: Bar chart with 7 categories and 4 values [message #100964 is a reply to message #100758] Wed, 21 December 2005 04:54 Go to previous messageGo to next message
What version of BIRT are you using? if you use 1.0.1, please get 2M3 and try
again.
David
"Stefan Knieling" <prooteus_NOSPAM@gmx.net> wrote in message
news:do8u43$o5h$1@utils.eclipse.org...
> When I render the bar chart programmatically, the following stacktrace is
> produced:
> org.eclipse.birt.chart.exception.ChartException: Horizontal axis contains
> at
> at
> at
> // Y-Series
> strings.
> Stefan
Re: Bar chart with 7 categories and 4 values [message #101005 is a reply to message #100964] Wed, 21 December 2005 05:28 Go to previous message
Hi David,
I have now tried with a nightly build from 6th december and the same
exception is thrown. Later I can also test with 2.0M3.
Stefan
Previous Topic:chart with missing data
Next Topic:limit the number of rows used for constructing a chartt?
Current Time: Sat Nov 08 23:59:23 EST 2025
Powered by FUDForum. Page generated in 0.03393 seconds
