Home » Eclipse Projects » Equinox » JSP osgi server example : how start the exemple?
JSP osgi server example : how start the exemple? [message #100669] Tue, 30 October 2007 10:23 Go to next message
hello,
JSP osgi server example : how start the example?
regards
xavier
Re: JSP osgi server example : how start the exemple? [message #100716 is a reply to message #100669] Wed, 31 October 2007 06:10 Go to previous messageGo to next message
Originally posted by: lifesting.gmail.com
Xavier Méhaut wrote:
> hello,
> regards
> xavier
Three steps:
Step-1: Download Eclipse Equinox SDK from eclipse.org and set the
*Target Platform* to Equinox (select sequence is
Windows->Preference->Plug-in Development->Target Platform).
Step-2: Open the file MANIFEST.MF in the example project.
Step-3: Select the *Overview* tab and locate on section *Testing*, you
could see two links, one is *Lanuch the framework* and the other is
*Lanuch the framework in Debug Mode*. Click one according to your need.
Re: JSP osgi server example : how start the exemple? [message #100729 is a reply to message #100716] Wed, 31 October 2007 06:51 Go to previous messageGo to next message
Thanks..
I've already followed these stpes without result ; how can I access the
web files through the navigator then(eg soemting like
http://localhost:9090/index.html)
regards
Xavier
>> hello,
>> regards
>> xavier
> Three steps:
Re: JSP osgi server example : how start the exemple? [message #100742 is a reply to message #100716] Wed, 31 October 2007 06:53 Go to previous message
Here is my manifest.mf file :
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Examples Plug-in
Bundle-SymbolicName: org.eclipse.equinox.jsp.examples
Bundle-Version: 1.0.0
Bundle-Activator: org.eclipse.equinox.jsp.examples.Activator
Bundle-Localization: plugin
Import-Package: javax.servlet;version="2.4.0",
javax.servlet.http;version="2.4.0",
javax.servlet.jsp;version="2.0.0",
javax.servlet.jsp.el;version="2.0.0",
javax.servlet.jsp.jstl.core,
javax.servlet.jsp.jstl.fmt,
javax.servlet.jsp.jstl.sql,
javax.servlet.jsp.jstl.tlv,
javax.servlet.jsp.resources;version="2.0.0",
javax.servlet.jsp.tagext;version="2.0.0",
javax.servlet.resources;version="2.4.0",
org.apache.taglibs.standard,
org.apache.taglibs.standard.extra.spath,
org.apache.taglibs.standard.functions,
org.apache.taglibs.standard.lang.jstl,
org.apache.taglibs.standard.lang.jstl.parser,
org.apache.taglibs.standard.lang.jstl.test,
org.apache.taglibs.standard.lang.jstl.test.beans,
org.apache.taglibs.standard.lang.support,
org.apache.taglibs.standard.resources,
org.apache.taglibs.standard.tag.common.core,
org.apache.taglibs.standard.tag.common.fmt,
org.apache.taglibs.standard.tag.common.sql,
org.apache.taglibs.standard.tag.common.xml,
org.apache.taglibs.standard.tag.el.core,
org.apache.taglibs.standard.tag.el.fmt,
org.apache.taglibs.standard.tag.el.sql,
org.apache.taglibs.standard.tag.el.xml,
org.apache.taglibs.standard.tag.rt.core,
org.apache.taglibs.standard.tag.rt.fmt,
org.apache.taglibs.standard.tag.rt.sql,
org.apache.taglibs.standard.tag.rt.xml,
org.apache.taglibs.standard.tei,
org.apache.taglibs.standard.tlv,
org.eclipse.equinox.jsp.jasper,
org.osgi.framework;version="1.3.0",
org.osgi.service.http;version="1.2.0",
org.osgi.util.tracker;version="1.3.1"
Bundle-ClassPath: web/WEB-INF/classes/,
Require-Bundle: org.eclipse.equinox.jsp.jstl,
org.eclipse.equinox.jsp.jasper.registry,
org.eclipse.equinox.http.helper
>> hello,
>> regards
>> xavier
> Three steps:
Previous Topic:basic jetty configuration question
Next Topic:How can I move jetty based bundle to servletbridge based environment?
Current Time: Sun Aug 31 04:27:35 EDT 2025
Powered by FUDForum. Page generated in 0.03685 seconds
