Home » Eclipse Projects » Equinox » JSP osgi server example : how start the exemple?
| Re: JSP osgi server example : how start the exemple? [message #100742 is a reply to message #100716] |
Wed, 31 October 2007 06:53  |
Here is my manifest.mf file :
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Examples Plug-in
Bundle-SymbolicName: org.eclipse.equinox.jsp.examples
Bundle-Version: 1.0.0
Bundle-Activator: org.eclipse.equinox.jsp.examples.Activator
Bundle-Localization: plugin
Import-Package: javax.servlet;version="2.4.0",
javax.servlet.http;version="2.4.0",
javax.servlet.jsp;version="2.0.0",
javax.servlet.jsp.el;version="2.0.0",
javax.servlet.jsp.jstl.core,
javax.servlet.jsp.jstl.fmt,
javax.servlet.jsp.jstl.sql,
javax.servlet.jsp.jstl.tlv,
javax.servlet.jsp.resources;version="2.0.0",
javax.servlet.jsp.tagext;version="2.0.0",
javax.servlet.resources;version="2.4.0",
org.apache.taglibs.standard,
org.apache.taglibs.standard.extra.spath,
org.apache.taglibs.standard.functions,
org.apache.taglibs.standard.lang.jstl,
org.apache.taglibs.standard.lang.jstl.parser,
org.apache.taglibs.standard.lang.jstl.test,
org.apache.taglibs.standard.lang.jstl.test.beans,
org.apache.taglibs.standard.lang.support,
org.apache.taglibs.standard.resources,
org.apache.taglibs.standard.tag.common.core,
org.apache.taglibs.standard.tag.common.fmt,
org.apache.taglibs.standard.tag.common.sql,
org.apache.taglibs.standard.tag.common.xml,
org.apache.taglibs.standard.tag.el.core,
org.apache.taglibs.standard.tag.el.fmt,
org.apache.taglibs.standard.tag.el.sql,
org.apache.taglibs.standard.tag.el.xml,
org.apache.taglibs.standard.tag.rt.core,
org.apache.taglibs.standard.tag.rt.fmt,
org.apache.taglibs.standard.tag.rt.sql,
org.apache.taglibs.standard.tag.rt.xml,
org.apache.taglibs.standard.tei,
org.apache.taglibs.standard.tlv,
org.eclipse.equinox.jsp.jasper,
org.osgi.framework;version="1.3.0",
org.osgi.service.http;version="1.2.0",
org.osgi.util.tracker;version="1.3.1"
Bundle-ClassPath: web/WEB-INF/classes/,
Require-Bundle: org.eclipse.equinox.jsp.jstl,
org.eclipse.equinox.jsp.jasper.registry,
org.eclipse.equinox.http.helper
> Xavier Méhaut wrote:
>> hello,
>> JSP osgi server example : how start the example?
>> regards
>> xavier
> Three steps:
> Step-1: Download Eclipse Equinox SDK from eclipse.org and set the
> *Target Platform* to Equinox (select sequence is
> Windows->Preference->Plug-in Development->Target Platform).
> Step-2: Open the file MANIFEST.MF in the example project.
> Step-3: Select the *Overview* tab and locate on section *Testing*, you
> could see two links, one is *Lanuch the framework* and the other is
> *Lanuch the framework in Debug Mode*. Click one according to your need.
Current Time: Sun Nov 09 06:54:23 EST 2025
Powered by FUDForum. Page generated in 0.03574 seconds
