Home » Eclipse Projects » Eclipse Platform » Adding a plugin from the wizard problem
Adding a plugin from the wizard problem [message #100619] Sat, 26 July 2003 15:58
Originally posted by: Mike.kordik.net
I wanted the c# plugin so I found Improve's plugin site and followd the
directions posted there. I added a feature update for Improve's Eclipse
plugin site and went to the c# plugin entry. In the preview pane I selected
install. When I get to the point in the wizard where is is asking for the
install location the list is empty. If I select Add... and select a
directory and press OK there is no entry. I either get an error saying the
directory exists or "Target location must be selected. If none is
available, create a new one". I tried many directories but no luck. What
am I doing wrong here?
I am running Gentoo Linux btw
Thx
Previous Topic:How do i Import a java project into Workspace by programming
Next Topic:Opening an editor on a non workspace file
Current Time: Wed Nov 05 11:41:02 EST 2025
Powered by FUDForum. Page generated in 0.23652 seconds
