Home » Archived » M2M (model-to-model transformation) » [ATL] Problem with UML elementImport on Emf VM
[ATL] Problem with UML elementImport on Emf VM [message #100562] Mon, 23 February 2009 17:00 Go to next message
I can't get this to work..
Trying to create output model with elementImports referencing elements
from input model.
Transformation is simple and looks like:
create model : UML from modelLibrary : UML;
rule pckg2pckg
from iP:UML!Package
to oP:UML!Package
elementImport <-
iP.packagedElement->select(e|e.oclIsTypeOf(UML!Class))->collect(e|thisModule.e2Ei(e)),
name <- iP.name
lazy rule e2Ei
from c:UML!Class
to ei:UML!ElementImport
importedElement<-c
Works great on Regular VM:
element imports in output model:
<elementImport xmi:id="_Y2AxMQH0Ed6V29UEYgb8Sw">
<importedElement xmi:type="uml:Class"
href=" platform:/resource/atl_test/models/modelLibrary.uml#_nwVVEAH sEd6V29UEYgb8Sw "/>
</elementImport>
Unfortunately not working on Emf-VM
<elementImport xmi:id="_nWNEMQH0Ed6V29UEYgb8Sw"/>
AllowInterModelReferences option doesn't change anything on both vm's
Need to use Emf-vm supporting stereotypes.
Looks like a bug?
Matt
Re: [ATL] Problem with UML elementImport on Emf VM [message #100576 is a reply to message #100562] Tue, 24 February 2009 05:51 Go to previous messageGo to next message
Which version of ATL are you using ?
I tried on both VMs in ATL3.0.0M5, using allowInterModelReferences
option, and it works.
William
Matt Fomr a écrit :
> Hi
> from input model.
> rule pckg2pckg
> from iP:UML!Package
> to oP:UML!Package
> elementImport <-
> name <- iP.name
> lazy rule e2Ei
> from c:UML!Class
> importedElement<-c
> </elementImport>
> Looks like a bug?
> Regards
> Matt
Re: [ATL] Problem with UML elementImport on Emf VM [message #100604 is a reply to message #100576] Tue, 24 February 2009 17:10 Go to previous message
You're right, works perfectly on 3.0.0M5
I was using ver. 2.0.0 from ganymede release, next time I'll make sure to
be up to date before posting.
Thanks for help!
Matt
Previous Topic:[ATL] Problem when trying to compile programmatically an ATL file with ATL 3.0
Next Topic:[ATL] can't using a UML modeler(Papyrus) to generate metamodels(KM3 , ecore)
Current Time: Mon Jul 14 07:12:29 EDT 2025
Powered by FUDForum. Page generated in 0.06602 seconds
