Home » Language IDEs » Java Development Tools (JDT) » Bug #30855 - Nesting error message specifying class folder
Bug #30855 - Nesting error message specifying class folder [message #100515] Thu, 02 October 2003 10:13 Go to next message
Originally posted by: eclipse.jaaj.net
HI,
This is in reference to the eclipse bug #30855 (Wrong error message
when nesting source folder in class folder).
I installed eclipse version 2.1.1 yesterday. However, I'm still getting the
same nesting error when I try to add a class folder to my build path.
Could you let me know if this bug has been fixed in version 2.1.1? If so,
how does this work?
Thanks for your help.
- Prab
Re: Bug #30855 - Nesting error message specifying class folder [message #100543 is a reply to message #100515] Thu, 02 October 2003 10:30 Go to previous message
Yes, according to the build notes for 2.1.1, this bug was even fixed for
2.1.
You should now get "Cannot nest 'P/lib/src' inside library 'P/lib".
Isn't it the message you get?
"Prab" <eclipse@jaaj.net> wrote in message news:blhbqs$v44$1@eclipse.org...
> HI,
the
> how does this work?
> - Prab
Previous Topic:howto dynamically append the java classpath
Next Topic:Newbe: Problem With JDT Install
Current Time: Sat Nov 08 05:22:44 EST 2025
Powered by FUDForum. Page generated in 0.03293 seconds
