Home » Archived » M2M (model-to-model transformation) » [ATL] Problem when trying to compile programmatically an ATL file with ATL 3.0
[ATL] Problem when trying to compile programmatically an ATL file with ATL 3.0 [message #100503] Mon, 23 February 2009 05:51 Go to next message
Hi all,
I'm experiencing issues when trying to compile an ATL file in .asm with
the
ATL 3.0 api. I'm trying to do this like this:
meo2atl.execute(mapping, model, ontology);
String content = meo2atl.serialize();
AtlCompiler.compile(
new ByteArrayInputStream(content.getBytes()),
fileName
meo2atl is a call to an high order transformation that produces an ATL
model.
I serialize this ATL file by calling the method serialize and put it in
content. But when trying to call the AtlCompiler i got the following
errors. Can someone tell me where i'm wrong?
thanks.
java.lang.RuntimeException: Eclipse platform extension registry not found.
Dynamic repository lookup does not work outside Eclipse.
org.eclipse.m2m.atl.engine.vm.AtlModelHandler.getDefault(Atl ModelHandler.java:69)
at org.eclipse.m2m.atl.engine.parser.AtlParser.<init>(AtlParser.java:46)
org.eclipse.m2m.atl.engine.parser.AtlParser.getDefault(AtlPa rser.java:56)
org.eclipse.m2m.atl.engine.compiler.AtlDefaultCompiler.inter nalCompile(AtlDefaultCompiler.java:124)
org.eclipse.m2m.atl.engine.compiler.AtlDefaultCompiler.compi leWithProblemModel(AtlDefaultCompiler.java:68)
org.eclipse.m2m.atl.engine.compiler.AtlCompiler.compile(AtlC ompiler.java:149)
l3i.sido.emf4sw.mood.mapper.compiler.MeoLauncherFactory.doCo mpile(MeoLauncherFactory.java:77)
l3i.sido.emf4sw.mood.mapper.compiler.MeoLauncherFactory.comp ile_object2rdf(MeoLauncherFactory.java:109)
l3i.sido.emf4sw.mood.mapper.compiler.MeoLauncherFactory.newL auncher(MeoLauncherFactory.java:54)
l3i.sido.emf4sw.mood.mapper.session.TripleStoreConfiguration .configure(TripleStoreConfiguration.java:111)
at org.example.library.app.Application.<init>(Application.java:27)
at org.example.library.app.Application.main(Application.java:33 )
l3i.sido.emf4sw.mood.atl.impl.Meo2Atl4Rdf2Model.execute(Meo2 Atl4Rdf2Model.java:49)
l3i.sido.emf4sw.mood.atl.impl.Meo2Atl4Rdf2Model.execute(Meo2 Atl4Rdf2Model.java:1)
l3i.sido.emf4sw.mood.mapper.compiler.MeoLauncherFactory.doCo mpile(MeoLauncherFactory.java:74)
l3i.sido.emf4sw.mood.mapper.compiler.MeoLauncherFactory.comp ile_rdf2object(MeoLauncherFactory.java:138)
l3i.sido.emf4sw.mood.mapper.compiler.MeoLauncherFactory.newL auncher(MeoLauncherFactory.java:55)
Re: [ATL] Problem when trying to compile programmatically an ATL file with ATL 3.0 [message #100548 is a reply to message #100503] Mon, 23 February 2009 07:54 Go to previous message
Hi Guillaume,
I guess you don't launch your application as a plugin, so the extension
registry (which usually loads model handlers) doesn't work.
In your case you must first register the AtlEMFModelHandler (which is
used by the AtlParser):
AtlModelHandler.registerDefaultHandler("EMF", new AtlEMFModelHandler());
// then compile etc...
Then the model handler will be directly available and the "getDefault"
method will bypass the extension lookup.
Best Regards,
William
Guillaume Hillairet a écrit :
> Hi all,
> the ATL 3.0 api. I'm trying to do this like this:
> new ByteArrayInputStream(content.getBytes()), fileName
> model.
> thanks.
> found. Dynamic repository lookup does not work outside Eclipse.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
Previous Topic:[QVTO] Blackboxing: how to set context?
Next Topic:[ATL] Problem with UML elementImport on Emf VM
Current Time: Sat Nov 08 22:31:58 EST 2025
Powered by FUDForum. Page generated in 0.02933 seconds
