Home » Newcomers » Newcomers » jardesc from ant in eclipse
jardesc from ant in eclipse [message #100432] Thu, 08 September 2005 11:28 Go to next message
Is it possible to have a jar generate from a jardesc using an ant task?
While we're at it does anyone know of a reference for the ant tasks that
come with eclipse (only 3 of them are described in the docs)? Finally, on
a related note, what properties are visible to ant whilst in eclipse?
Andrew
Re: jardesc from ant in eclipse [message #100445 is a reply to message #100432] Thu, 08 September 2005 11:36 Go to previous messageGo to next message
1.Sorry...I don't know.
2. No. I would log bug reports against the providing plugins/teams to get
some better doc. Eclipse will provide content assist for the tasks but you
will still need to "guess" at the functionality without doc.
3. echoproperties will give you a complete listing. This will change
depending on if you are running in the same or separate JRE than the
workspace (see the JRE tab for your Ant launch configuration). Or you can
debug an Ant build and check out the Debug Variables view to display the
current set of properties.
HTH
Darins
<aeberbac@us.ibm.com> wrote in message news:dfplan$bbq$1@news.eclipse.org...
> Hello,
> Andrew
Re: jardesc from ant in eclipse [message #100715 is a reply to message #100432] Fri, 09 September 2005 06:48 Go to previous message
Originally posted by: daniel.megert.gmx.net
aeberbac@us.ibm.com wrote:
>Hello,
No.
Dani
>Thanks,
>Andrew
Previous Topic:Eclipse's keyboard layout changed without notice
Next Topic:IDE cvs does not recognize custom tags/branches automatically
Current Time: Mon Nov 10 19:16:05 EST 2025
Powered by FUDForum. Page generated in 0.09722 seconds
