Home » Archived » BIRT » compilation of BIRT source codes shows error in eclipse3.1.1
compilation of BIRT source codes shows error in eclipse3.1.1 [message #100405] Sun, 18 December 2005 23:58 Go to next message
Originally posted by: harikrishnan_j2003.yahoo.co.in
goal:-(i)i am trying to run the BIRT source codes after downloading it,but
it shows error.Right now the way is to download the codes from cvs
repository,which automatically compiles in eclipse after completion.it
should show only warnings,not errors indicating successful compilation
(ii)i should have runtime workbench option in eclipse3.1.1 to run this,but
it is not available in eclipse3.1.1(iii)i want to know main file of BIRT
source code to understand the flow better,right now there are so many
files that contain main method in it.
query 1
error message when i execute BIRT code:-
BUILD FAILED
C:\eclipse3.1.1\eclipse\workspace\org.eclipse.birt.report.vi ewer\BuildViewer.xml:207:
The following error occurred while executing this line:
C:\eclipse3.1.1\eclipse\workspace\org.eclipse.birt.report.mo del\BuildModel.xml:310:
C:\eclipse3.1.1\eclipse\workspace\org.eclipse.birt.data.oda\ BuildOda.xml:196:
Basedir
C:\eclipse3.1.1\eclipse\workspace\org.eclipse.datatools.conn ectivity.oda
does not exist
but org.eclipse.datatools.connectivity.oda exist in that place
Environment on which it occurs:-
1.windows 2000 professional
2.eclipse BIRT report designer framework 1.0.1
3.eclipse modeling framework2.1.1
4.graphic editor framework 3.1.1
5.jdk1.4
i gone through BIRT build page,documentation,faq.In that they are given
that it will be compiled successfully after downloading,but I am getting
above error.
query 2
I am not getting runtime workbench option in my eclipse3.1.1 to run BIRT
source codes.I updated the eclipse ,still i am not getting it.
query 3
i cannot find the main file in eclipse BIRT source codes to get the FLOW
of project.i have explored the source codes,but it has many main files.it
is confusing to me .i have gone through BIRT documentation,faq.
i thankyou for your attention, inspite of your busy hours.
Thankyou&Regards
J.Harikrishnan
R.Jegadeeswari
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #100833 is a reply to message #100405] Tue, 20 December 2005 12:30 Go to previous messageGo to next message
BIRT 2.0 has moved data access to the DTP project. You will need to download
the libs or the source from http://www.eclipse.org/datatools/
In addition you will need to add the required libs (Right now I think this
is just iText.jar)
As we get closer to 2.0 final I will update the build instructions on the
web site.
You may want to look at org.eclipse.birt.report.designer.ui. This is one of
the main plugins for the report designer perspective.
Jason Weathersby
BIRT PMC
"Hari Krishnan" <harikrishnan_j2003@yahoo.co.in> wrote in message
news:c818e12fe100ffaafc7bb73bfab65856$1@www.eclipse.org...
> query 1
> BUILD FAILED
> Basedir
> does not exist
> 1.windows 2000 professional 2.eclipse BIRT report designer framework
> 1.0.1
> 5.jdk1.4
> above error.
> query 2
> query 3
> Thankyou&Regards
> J.Harikrishnan
> R.Jegadeeswari
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #101102 is a reply to message #100833] Wed, 21 December 2005 07:56 Go to previous messageGo to next message
Sir,
we Thankyou for your reply to us.
we are getting the same error message again .we downloaded datatools
through cvs in to the workspace where our BIRT code resides and we also
downloaded itext-1.3.jar and copied into
plugins\org.eclipse.birt.report.engine.emitter.fo\lib.we cleaned the
project & rebuilded once again with this changes,but we are getting the
same error message,what we got before.
we have:-
1.birt-report-framework-1_0_1
2.JRE 1.4
3.Eclipse SDK 3.1.1
4.Graphics Editor Framework (GEF) runtime 3.1.1
5.Eclipse Modeling Framework (EMF) runtime 2.1.1
so we updated our BIRT to try once again:-
1.birt-report-framework-2.0M3
2.The Simple API for CSS SAC 1.3
3.Flute 1.2
4.iText 1.3
again builded,but not successful at this time also,it is showing the same
error.The error files are BuildViewer.xml,BuildModel.xml,BuildOda.xml
files is there is anything that i have to change in these file to rectify
this error
or is there any tool or configurations that we have to set up to
successfully compile the source codes.
I apologize to you,for wanting your attention once again.
Thankyou
Harikrishnan J.
Jegadeeswari R.
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #101243 is a reply to message #101102] Wed, 21 December 2005 12:48 Go to previous messageGo to next message
Did the datatools projects build? Did any of the BIRT projects build?
It looks like you have set it, but verify DTP home is set.
Jason
news:d0f039d16b6443133958d4c99acc5162$1@www.eclipse.org...
> Sir,
> we have:-
> 2.JRE 1.4
> 3.Eclipse SDK 3.1.1 4.Graphics Editor Framework (GEF) runtime 3.1.1
> 2.The Simple API for CSS SAC 1.3 3.Flute 1.2 4.iText 1.3
> this error
> Thankyou
> Harikrishnan J.
> Jegadeeswari R.
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #101519 is a reply to message #101243] Thu, 22 December 2005 03:54 Go to previous messageGo to next message
Sir,
we Thankyou for your swift reply to our mail.we changed the dtp home
setting,we executed Buildviewer.xml in org.eclipse.birt.report.viewer
through ant build as prescribed ,we succeded in fixing that error,but new
error came
in our path.
error message what we got:-
nativeToAsciiUtil:
[native2ascii] Converting 3 files from D:\Hari
Krishnan\workspace\org.eclipse.datatools.connectivity\plugin s\org.eclipse.datatools.connectivity.oda\src\org\eclipse\dat atools\connectivity\oda\util
to D:\Hari
BUILD FAILED
D:\Hari
Krishnan\workspace\org.eclipse.birt.report.viewer\BuildViewe r.xml:207: The
D:\Hari
Krishnan\workspace\org.eclipse.birt.report.model\BuildModel. xml:310: The
D:\Hari Krishnan\workspace\org.eclipse.birt.data.oda\BuildOda.xml:19 6: The
D:\Hari
Krishnan\workspace\org.eclipse.datatools.connectivity\plugin s\org.eclipse.datatools.connectivity.oda\build.xml:74:
D:\Hari
Krishnan\workspace\org.eclipse.datatools.connectivity\plugin s\org.eclipse.datatools.connectivity.oda\build.xml:128:
Error starting Sun's native2ascii:
It is saying there is a Error in starting sun's native2ascii
Line indicated as containing error present in:-
org.eclipse.datatools.connectivity.oda/build.xml
Errorlines:-
<antcall target="oda.jar"/>
<target name="nativeToAsciiUtil">
<native2ascii encoding="Cp1252"
src="${oda.src.dir}/util"
dest="${oda.src.dir}/util"
ext=".java"
includes="OdaResources_de_DE.msg, OdaResources_fr_FR.msg,
OdaResources_es_ES.msg"/>
these three files exist in the source path and while converting this it
shows error.
we gone through this set of lines to rectify this error ourself,but as we
are a newbies,we don't know how to correct this, so failed in our attempt.
our goal is to successfully execute the whole set of BIRT codes.
we are feeling awkward in repeatedly disturbing you for solutions.
Apologize us
Thankyou
HariKrishna j.
Jegadeeswari R.
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #101761 is a reply to message #101519] Thu, 22 December 2005 13:37 Go to previous messageGo to next message
Make sure drive\jdk\bin is in your path.
I reproduced this problem by removing mine.
I also had to set eclipse.home to my Eclipse install directory.
HTH
Jason
news:77699938dd64f303ff13af46cf5dde16$1@www.eclipse.org...
> Sir,
> error came in our path.
> nativeToAsciiUtil:
> to D:\Hari
> BUILD FAILED
> D:\Hari
> D:\Hari
> D:\Hari
> D:\Hari
> Errorlines:-
> src="${oda.src.dir}/util" dest="${oda.src.dir}/util" ext=".java"
> shows error.
> Apologize us
> Thankyou
> HariKrishna j.
> Jegadeeswari R.
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #102027 is a reply to message #101761] Fri, 23 December 2005 04:02 Go to previous messageGo to next message
Sir,
We thankyou for your reply to us.
our goal:- to Execute successfully the whole set of BIRT codes
we have set drive\jdk\bin path in the class path variables of eclipse as
JAVA_HOME-C:/Program Files/Java/j2re1.4.2_07/bin
I have set the eclipse.home to my Eclipse install directory in the class
ECLIPSE_HOME-d:/eclipse3.1.1/eclipse as per your instructions
and builded once again but it shows same error "Error in starting sun's
native2ascii" .it pointing the errors in three files,we have given set of
lines which shows error in these three files and marked the line which
shows error as error line prefixed to that line.
BuildViewer.xml
<!-- Prepare Model related libraries -->
<target name="model" depends="init">
error line----- <ant dir="${viewer.model.dir}"
antfile="BuildModel.xml" target="Jar" inheritall="false"
inheritrefs="false">
<property name="eclipse.home"
value="${eclipse.home}" />
</ant>
</target>
BuildModel.xml
<!-- Build the dependent projects -->
<target name="buildDependents" description="Build all the
projects it depends on">
<echo message="start call Jar task in ${core.dir}"
level="info"/>
<ant dir="${core.dir}" antfile="BuildCore.xml"
target="Jar"
inheritall="false">
</ant>
<echo message="end call Jar task in ${core.dir}"
level="info" />
<!-- Building BIRT ODA triggers building of DTP ODA jar -->
<echo message="start call Jar task in ${data.oda.dir}"
level="info"/>
<echo message="dtp.home= ${dtp.home}"/>
error line------------ <ant dir="${data.oda.dir}" antfile="BuildOda.xml"
target="Jar" inheritall="false">
<property name="eclipse.home" value="${eclipse.home}" />
<property name="dtp.home" value="${dtp.home}" />
</ant>
<echo message="end call Jar task in ${data.oda.dir}"
level="info" />
</target>
BuildOda.xml
<!-- Generate the apiJavaDoc.
Parameters:
- ${api.javadoc.dir} target directory to put
the java document
<target name="buildDependency">
<echo message="start call Jar task in ${core.dir}"/>
<ant dir="${core.dir}" antfile="BuildCore.xml" target="Jar"
inheritall="false">
</ant>
<echo message="end call Jar task in ${core.dir}"/>
<echo message="start call Jar task in ${dtp.oda.dir}"/>
error line------- <ant dir="${dtp.oda.dir}" antfile="build.xml"
target="build.jars" inheritAll="false">
</ant>
<echo message="end call Jar task in ${dtp.oda.dir}"/>
</target>
we have attached more content,why i have done this is , i want to show
the code which causes error, to get clear picture.
we thankyou for your attention towards us
Thankyou
Harikrishnan J.
Jegadeeswari R.
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #102146 is a reply to message #102027] Fri, 23 December 2005 13:58 Go to previous messageGo to next message
I had the jdk\bin directory in my system path.
Should not matter, but you may want to try that. Make sure you shut down
Eclipse and restart.
I rebuilt everything yesterday just to test this. It should work.
Jason
news:8853815789062861a30332dbd66775ec$1@www.eclipse.org...
> Sir,
> path variables of eclipse as ECLIPSE_HOME-d:/eclipse3.1.1/eclipse as per
> your instructions
> BuildViewer.xml
> </ant>
> </target>
> BuildModel.xml
> projects it depends on"> <echo message="start
> call Jar task in ${core.dir}" level="info"/>
> inheritall="false">
> </ant>
> <echo message="end call Jar task in ${core.dir}" level="info" />
> level="info"/>
> </ant>
> <echo message="end call Jar task in ${data.oda.dir}" level="info" />
> </target>
> BuildOda.xml
> Parameters:
> - ${api.javadoc.dir} target directory to put the java document
> inheritall="false">
> </ant>
> </ant> <echo message="end call Jar task in ${dtp.oda.dir}"/>
> </target>
> Thankyou Harikrishnan J.
> Jegadeeswari R.
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #102937 is a reply to message #102146] Thu, 29 December 2005 06:17 Go to previous messageGo to next message
Sir,
Wish you a Happy New Year from us.
We thank you for your guidance to us through mail.We have builded
successfully BuildViewer.xml file based on your instructions,but another
error came.
query-1
When we try to build test-old.xml in org.eclipse.birt.report.test.engine
it shows 1 error
missing required library:-
C:\apps\apache-ant-1.6.2\lib\ant.jar,C:\apps\apache-ant-1.6. 2\lib\ant-xalan1.jar,C:\apps\apache-ant-1.6.2\lib\ant-xalan2 .jar,C:\apps\apache-ant-1.6.2\lib\junit.jar,C:\apps\apache-a nt-1.6.2\lib\xercesimpl.jar,
we got those jar files and created lib path& put the jar files into it as
above and cleaned ,builded once again,but changes not reflected in the
test-old.xml file showing same err msg.it is not linking with the created
path,as that path not exist we have done this,still we get same err.
query-2
The field ReportDesign.STYLE_SLOT is ambiguous reported err msg in
DesignElementCloneTest.java which is present in
org.eclipse.birt.report.tests.regression.model/test/org/ecli pse/birt/report/model/core
we cannot resolve these errors.Apologize us for wanting you help
frequently.
Thankyou
Harikrishnan j.
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #103732 is a reply to message #102937] Tue, 03 January 2006 14:27 Go to previous messageGo to next message
Hari,
I deleted the test projects from my source, but make sure libs are in build
path.
Jason
news:e83d0cdcc1f6cc905982987cb82cd03d$1@www.eclipse.org...
> Sir,
> error came.
> query-1
> it shows 1 error
> query-2
> frequently.
> Thankyou
> Harikrishnan j.
Re: compilation of BIRT source codes shows error in eclipse3.1.1 [message #108189 is a reply to message #103732] Thu, 12 January 2006 09:23 Go to previous message
Sir,
We Thankyou for spending your valuable time in guiding and giving
instructions to us in the process of compiling the BIRT source codes
successfully.We acted as per your instructions and successfully executed
the whole BIRT source codes.
Thankyou
Harikrishnan J.
Jegeeshwari R.
Previous Topic:birt-viewer in 2.0: frameset?
Next Topic:DateTime Formatting and validation
Current Time: Wed Nov 19 19:19:12 EST 2025
Powered by FUDForum. Page generated in 0.32209 seconds
