Home » Eclipse Projects » GEF » ObjectTransferType?
ObjectTransferType? [message #100224] Wed, 15 October 2003 23:36 Go to next message
Originally posted by: snowice.asiamail.com
I realise that there are only FileTransferType, TextTransferType and
ByteArrayTransferType. Did anyone implement any ObjectTransferType? I
desperately need an ObjectTransfertype as the 3 available transfer types
cannot be used to satisfy my needs. In my tree viewer, it displays a tree
of "objects" which i need to drag and drop. However each object has quite
a number of nested objects hence ByteArrayTransferType does not seem
feasible. Can someone enlighten me? Thanks in advance!
regards,
Evon
Re: ObjectTransferType? [message #100417 is a reply to message #100224] Thu, 16 October 2003 21:09 Go to previous message
Originally posted by: ThisisFake.Fakeness.xyz
On Thu, 16 Oct 2003 03:36:21 +0000, Evon wrote:
> regards,
> Evon
byte array shoudl work just fine. Use an ObjectOutputStream and a
ByteArrayOutputStream, or input streams. some combination of those should
allow you to convert your object into a byte array. They must all
implement the serializable interface.
CL
Previous Topic:how to use logic sample ,thanks!!
Next Topic:Extending GraphicalEditorWithPalete
Current Time: Wed Jul 09 09:46:52 EDT 2025
Powered by FUDForum. Page generated in 0.05249 seconds
