Home » Archived » Test and Performance Tools Platform (TPTP) » collect method cpu time option
collect method cpu time option [message #100198] Tue, 05 June 2007 10:19 Go to next message
I am having a hard time identifying what exactly this option accomplished
in t execution statis monitoring
Re: collect method cpu time option [message #100285 is a reply to message #100198] Wed, 06 June 2007 02:49 Go to previous messageGo to next message
> accomplished in t execution statis monitoring
Can you provide more information on the Eclipse and TPTP versions you
are using and what is the exact use-case in question?
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: collect method cpu time option [message #100388 is a reply to message #100285] Wed, 06 June 2007 08:07 Go to previous messageGo to next message
Its an option on the monitor tab for execution statistcs. Eclipse 3.2
something. TPTP 4.2.1
Re: collect method cpu time option [message #100414 is a reply to message #100388] Wed, 06 June 2007 08:36 Go to previous message
Execution Statistics is used to determine the amount of time spent
inside each method of the profiled application. It has 2 modes of
operations:
- Summary (the default): summary information only. No "call tree"
information. Less overhead.
- Execution Flow Graphical Details: shows the relationships between
method invocations and allow that fancy views like execution trees and
UML sequence diagrams. High overhead. Should be used only with extensive
filtering to get meaningful results.
For more information, refer to the TPTP online documentation:
http://help.eclipse.org/help32/topic/org.eclipse.tptp.platfo rm.doc.user/concepts/ceproftl.htm
Or the TPTP tutorials:
http://www.eclipse.org/tptp/home/documents/communityresource s.php
HTH,
Asaf
Asaf Yaffe
Previous Topic:[tptp-4.3.1] IWAT4039E connection refused... / InactiveProcessException
Next Topic:Error installing AgentController on Linux
Current Time: Mon Sep 01 15:33:09 EDT 2025
Powered by FUDForum. Page generated in 0.03867 seconds
