Home » Archived » M2M (model-to-model transformation) » [ATL] Progress monitor
[ATL] Progress monitor [message #100074] Tue, 17 February 2009 04:20 Go to next message
Hi, I am launching Atl transformations by code and I want to add a
progress monitor to the user knows which is the state of the
transformation.
Is it possible ?¿?
My Eclipse version is 3.4 and ATL version is 2.0
Re: [ATL] Progress monitor [message #100699 is a reply to message #100074] Wed, 25 February 2009 06:24 Go to previous messageGo to next message
I have seen in AtlLaunchConfigurationDelegate class that the method
launched when you click on the button "Run" uses a progress monitor.
I have a look to this progress monitor and I have seen that the progress
doesn't increase in time, it only increment a few and stop until
transformation finishes.
I think it should be improved to increase little by little while
transformation is been executed.
In the other hand, I want to use a progress monitor but I'm using method
"launch" of org.eclipse.m2m.atl.engine.AtlLauncher class but it doesn't
use progress monitor.
What can I do?¿? Do I change the way of calling ATL launcher ?¿?
Thanks a lot
Re: [ATL] Progress monitor [message #100743 is a reply to message #100699] Wed, 25 February 2009 08:39 Go to previous message
The problem is that the execution time computation is not as trivial as
it seems: it is related to many factors (models size, operations called
several times). At this time we don't have a solution which give a
significant result without decreasing performance.
In ATL3.0.0, the launch api has been redefined so there is now a
org.eclipse.m2m.atl.core.launch.ILauncher#launch method which takes a
ProgressMonitor.
William
> Thanks a lot
Previous Topic:[ATL] unique lazy rule
Next Topic:[ATL] Using own Ecore API with ATL
Current Time: Wed Dec 03 13:49:50 EST 2025
Powered by FUDForum. Page generated in 0.04023 seconds
