Slowdown with large projects [message #100047] |
Sun, 18 April 2004 19:19  |
Originally posted by: bmentink.trimble.co.nz
Hi all,
When we have a large C/C++ project loaded, we get massive interrmittant
slowdowns. i.e the java runtime goes to 99% for a period of time
and sometimes eclipse can crash and/or with a memory error.
I have also seen a "java heap" error on loading the large project
directory.
Eclipse seems to use a massive amount of RAM, with no projects about 50Mb,
with the mentioned project loaded, about 107Mb ... is this normal?
Are we seeing a memory problem, or is it something else.
I will post this to the Eclipse forum as well, as I don't know if it
is a Eclipse problem, or with the C/C++ plugin itself.
Bernie Mentink
Re: Slowdown with large projects [message #100267 is a reply to message #100120] |
Mon, 19 April 2004 17:58   |
Hi Alex,
I am using version 3.0M8 and the corresponding M8 version off CDT. Running
it
on a WinNT 2000 system. I suspect the problem is the "indexing" problem
mentioned elsewhere in the newsgroup.
Bernie
Alex Klein wrote:
> Hi Bernie,
> I've got that too using Eclipse 2.1, but I'm not sure if eclipse 3.0
> also has that problem. From the short time I looked into eclipse 3, it
> seemed to have a much better performance. Could not test it on a larger
> project as I have some problems with 3.0M8 as posted in another thread
> (from which the most current is that the build-output does not show up
> in the console ... any ideas on that yet?). Maybe it helps if you post
> your OS and eclipse version.
> Most notably, the problem shows up when saving a file or doing a build.
> Simply saving a file sometimes is quite fast, but more often it takes up
> to half a minute. When building, updating of the project after the build
> is complete may also take half a minute. Don't know what exactely causes
> it...
> I use Suse 8.2 with J2SDK1.4.2_04 from Sun, Eclipse 2.1.2 and CDT 1.2.0.
> The project is about 5000 lines of code and the whole workspace is about
> 70MB including binaries and data files. Hope that helps to narrow it down...
> Alex
Re: Slowdown with large projects [message #100349 is a reply to message #100267] |
Tue, 20 April 2004 09:47  |
Bernie Mentink wrote:
> Hi Alex,
> it
I'm seeing exactly what you're seeing. 3.0M8, Win2000, and up to 107MB
or so of memory in use by javaw.exe and stretches of several minutes
where it uses 99% of the CPU. I routinely have 5-10 files open at a
time. I don't think I saw anything like that with Eclipse 2.1, this is
different from that problem that kept updating the Outline.
Rick
> Cheers,
> Bernie
> Alex Klein wrote:
>>Hi Bernie,
>>it...
>>Alex
FUDForum. Page generated in 0.03976 seconds
