Home » Archived » M2M (model-to-model transformation) » Obtain SQL schema from UML class diagram
Obtain SQL schema from UML class diagram [message #100045] Mon, 16 February 2009 04:48
I have UML class digram and I want to obtain SQL schema from it.
We have CWM Relation meta-model so I think that it is nature to
use this meta-model to produce SQL schema.
I have UML class that conforms to UML meta-model, so it is nature to
transform this UML class model into CWM relation model that conforms to
CWM metamodel,
and after that use transformation to get SQL DDL.
So I can create UML profile for database or use if it exists (it must
exists)
and use it to describe relation model using it.
Does anyone now any tool that can produce SQL schema from CWM model
or have any good idea about this problem.
Thanks in advance
Dusan
Previous Topic:XSD -> Ecore -> XML <- ATL -> XML -> Ecore -> XSD
Next Topic:[ATL] (3.0) New JAVA ATL3.0 launch procedure?!
Current Time: Mon Jul 14 07:20:39 EDT 2025
Powered by FUDForum. Page generated in 0.07181 seconds
