Home » Language IDEs » PHP Development Tools (PDT) » PDT 2.1 fails to load properly
PDT 2.1 fails to load properly [message #99519] Sun, 05 July 2009 01:44 Go to next message
I noticed that, in some cases, the PDT fails to load properly. Most users
will not notice the problem - PDT seems to work fine, but some advanced
features will not work. This includes completion and resolution in some
cases. There is an error in the log which is described below.
This is clearly bug, but I'm having trouble pinpointing where and when it
happens. I noticed that this can happen with a clean PDT All-in-one
download running on Windows XP - but it won't happen in all cases.
People - please check you error logs. If you are experiencing this problem
please let me know so we can try to understand in which cases it happens.
Zviki
The error may take all kind of shapes and sizes, but eventually it will
boil down to java.lang.NoClassDefFoundError for
org/eclipse/php/internal/core/typeinference/evaluators/Varia bleReferenceEvaluator$LocalReferenceDeclSearcher
This may originate at different locations.
java.lang.NoClassDefFoundError:
org.eclipse.php.internal.core.ast.nodes.DefaultBindingResolv er. <init>(DefaultBindingResolver.java:86)
org.eclipse.php.internal.core.ast.nodes.ASTParser.<init>(ASTParser.java:63)
org.eclipse.php.internal.core.ast.nodes.ASTParser.newParser( ASTParser.java:96)
org.eclipse.php.internal.ui.editor.validation.PhpReconciling Strategy.reconcile(PhpReconcilingStrategy.java:139)
org.eclipse.php.internal.ui.editor.validation.PhpReconciling Strategy.access$0(PhpReconcilingStrategy.java:122)
org.eclipse.php.internal.ui.editor.validation.PhpReconciling Strategy$2.run(PhpReconcilingStrategy.java:206)
org.eclipse.php.internal.ui.editor.validation.PhpReconciling Strategy.validate(PhpReconcilingStrategy.java:204)
org.eclipse.php.internal.ui.editor.validation.PhpReconciling Strategy.validate(PhpReconcilingStrategy.java:186)
org.eclipse.wst.sse.ui.internal.reconcile.validator.Reconcil eStepForValidator.validate(ReconcileStepForValidator.java:29 2)
org.eclipse.wst.sse.ui.internal.reconcile.validator.Reconcil eStepForValidator.reconcileModel(ReconcileStepForValidator.j ava:258)
org.eclipse.jface.text.reconciler.AbstractReconcileStep.reco ncile(AbstractReconcileStep.java:95)
org.eclipse.wst.sse.ui.internal.reconcile.validator.Validato rStrategy.reconcile(ValidatorStrategy.java:257)
org.eclipse.wst.sse.ui.internal.reconcile.DocumentRegionProc essor.process(DocumentRegionProcessor.java:199)
org.eclipse.wst.sse.ui.internal.reconcile.StructuredRegionPr ocessor.process(StructuredRegionProcessor.java:221)
org.eclipse.wst.sse.ui.internal.reconcile.DirtyRegionProcess or.run(DirtyRegionProcessor.java:641)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.php.internal.core.typeinference.evaluators.Varia bleReferenceEvaluator$LocalReferenceDeclSearcher
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:489)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 17 more
Re: PDT 2.1 fails to load properly [message #99534 is a reply to message #99519] Sun, 05 July 2009 05:32 Go to previous message
I don't have this error in my logs. WinXP SP2 newset PDT 2.1 downloaded from zend
Previous Topic:[Announce] PDT 2.1.0 is available
Next Topic:Bug: Creation of element failed. Reason: Build path contains duplicate entry for project
Current Time: Sat Nov 08 23:59:20 EST 2025
Powered by FUDForum. Page generated in 0.04393 seconds
