Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Compare] extensibility
[Compare] extensibility [message #99395] |
Wed, 17 October 2007 07:44  |
will be in future possible to use another formats for LOADING/STORING of
data?
Possibly for load/store model in multiple files?
For example via extension point mechanism.
best Regards,
Jan
Re: [Compare] extensibility [message #99439 is a reply to message #99410] |
Wed, 17 October 2007 09:21   |
I did some debuging and found that for loading is used your utility
ModelUtils.
There are some methods for load the Resource. Could it be somehow extensible
so that used can provide his own implemetation of this load method for a
file, registered lets say by content type?
Best Regards,
Jan
"laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
news:ff4vge$6i1$1@build.eclipse.org...
> Jan,
> I don't really understand what you describe as "data".
> Storing data : if you are talking about the result of the comparison, it
> is already possible to alter the way it is saved. Currently an action is
> implemented to save the result as "emfdiff" which contains both the diff
> model and the match model. The extension point
> "org.eclipse.emf.compare.ui.export" allows you to define new actions for
> the "export" menu.
> Loading data : if you are talking about the way we load the two models
> to be compared ... well we don't :) org.eclipse.compare does this job
> and sends us streams to the models to be compared. That is for the "GUI
> usage" of emf compare. If you compare objects from code instead, it is
> up to you to load your EObjects in memory and call a comparison on them
> using MatchService#modelMatch(EObject, EObject, ProgressMonitor).
> Starting from here, it should be possible to load your models from
> multiple files in the same ResourceSet and compare them.
> Laurent Goubet
> Obeo
> eclipsemaniac a
Re: [Compare] extensibility [message #99464 is a reply to message #99439] |
Wed, 17 October 2007 09:49   |
--------------040903010302020702000409
Jan,
Note that in EMF 2.4 we added support for content types.
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=191077>
Unfortunately there's no documentation yet. The XMI plugin.xml shows
how the content type for Ecore Model content is registered.
eclipsemaniac wrote:
> Hello,
> ModelUtils.
> Best Regards,
> Jan
>> Jan,
>> the "export" menu.
>> Regards,
>> Laurent Goubet
>> Obeo
>> eclipsemaniac a
Re: [Compare] extensibility [message #99595 is a reply to message #99439] |
Thu, 18 October 2007 02:59  |
using emf you may define your own ResourceFactory associated with a file
extension. This resource factory has to provide a Resource implementation,
you may define your own loading/saving your model in a specific way.
EMF compare will automatically re-use that implementation.
Cédric
> Hello,
> ModelUtils.
> extensible so that used can provide his own implemetation of this load
> method for a file, registered lets say by content type?
> Best Regards,
> Jan
>> Jan,
>> the "export" menu.
>> Regards,
>> Laurent Goubet
>> Obeo
>> eclipsemaniac a
Re: [Compare] extensibility [message #610044 is a reply to message #99395] |
Wed, 17 October 2007 08:35  |
--------------060405020904090007070004
Jan,
the "export" menu.
Laurent Goubet
Obeo
eclipsemaniac a
Re: [Compare] extensibility [message #610048 is a reply to message #99410] |
ModelUtils.
Best Regards,
Jan
> Jan,
> the "export" menu.
> Laurent Goubet
> Obeo
> eclipsemaniac a
Re: [Compare] extensibility [message #610051 is a reply to message #99439] |
Jan,
> Hello,
> ModelUtils.
> Best Regards,
> Jan
>> Jan,
>> the "export" menu.
>> Regards,
>> Laurent Goubet
>> Obeo
>> eclipsemaniac a
Re: [Compare] extensibility [message #610069 is a reply to message #99439] |
Cédric
> Hello,
> ModelUtils.
> Best Regards,
> Jan
>> Jan,
>> the "export" menu.
>> Regards,
>> Laurent Goubet
>> Obeo
>> eclipsemaniac a
Current Time: Fri Jul 25 00:40:28 EDT 2025
Powered by FUDForum. Page generated in 0.17769 seconds
