Home » Language IDEs » PHP Development Tools (PDT) » Question PDT2.1 Auto Completion for PHP5.3
Question PDT2.1 Auto Completion for PHP5.3 [message #99380] Tue, 30 June 2009 09:46
Hi all,
I have problems with the Eclipse AutoComplete feature since some PDT
Releases. After each update the proposals needs more time to collect
(multiple seconds even for small projects) and fewer important results are
included (example: @var tags missing ...)
But with the actual PDT2.1 version almost nothing works for PHP5.3
projects (PHP5.2 is not affected).
Maybe i missed some things which i must do for completion.
Now it follows an example, where someone maybe can help me getting AC to
work (initial it had a much deeper structur, but even this little one
doesnŽt work)
Thank you & greetings
true
<?php
* Packet Classes Structure
* package1\Test (base class)
* - package2\Test2 implements package1\iTest
namespace package1 {
class Test {
public $someVar = "someValue";
public function someFunc() { echo "called someFunc"; }
public function someInterfaceFunc() { echo "called someInterfaceFunc"; }
public function outputSomeVar() {
echo "called outputSomeVar: ".$this->someVar; // <- no
AutoComplete here
interface iTest {
public function someInterfaceFunc();
namespace package2 {
class Test2 extends \package1\Test implements iTest {}
namespace main {
function callInterfaceFunc(\package1\iTest $obj)
$obj->someInterfaceFunc(); // <- no AutoComplete here
* Object Outputs
error_reporting(E_ALL);
ini_set("display_errors", "1");
$deepObject = new \package2\Test2(); // <- no AutoComplete here
$deepObject->someFunc(); // <- no AutoComplete here
echo "<br />----------<br />";
echo $deepObject->someVar; // <- no AutoComplete here
callInterfaceFunc($deepObject); // <- Here it finds the
Function
$baseObject = new \package1\Test(); // <- no AutoComplete here
$baseObject->outputSomeVar(); // <- no AutoComplete here
* Displayed Output
called someFunc
someValue
someValue
Previous Topic:Run as script - sometimes no output
Next Topic:Code Assist: completion and subnamespaces bug?
Current Time: Sun Jul 13 15:04:43 EDT 2025
Powered by FUDForum. Page generated in 0.03565 seconds
