Home » Language IDEs » C / C++ IDE (CDT) » How to use DirectX with CDT ?
How to use DirectX with CDT ? [message #99334] Sun, 11 April 2004 10:09 Go to next message
Originally posted by: hostgrabber.gmx.net
does anybody know how to use DirectX with Eclipse CDT?
Perhaps someone knows an tutorial or an webpage about it.
Thanks for help
Greetings
Heinz
Re: How to use DirectX with CDT ? [message #99350 is a reply to message #99334] Sun, 11 April 2004 20:28 Go to previous message
Originally posted by: cam.bitshifter.net.nz
Hi Heinz,
Eclipse CDT relies on MinGW or Cygwin to do it's compiling, so the first
thing you need to do is get your compiler working with DirectX. I use
MinGW, so I can post some info about that.
There is a mini tutorial on getting DirectX and MinGW playing together
on these forums:
http://forum.eyedolon.com/viewtopic.php?p=778#778
http://forum.eyedolon.com/viewtopic.php?p=1234#1234
The posts refer to the Dev-C++ IDE, but just replace Dev-C++ with
Eclipse CDT and everything should make sense.
I haven't actually got DirectX stuff building with Eclipse yet, but the
only hurdle I have is importing by existing projects into a new managed
CDT project. I have got DirectX9 stuff build with MinGW.
Hope this helps,
Cameron.
Heinz Werkle wrote:
> Thanks for help
> Greetings
> Heinz
Previous Topic:outline view in M8 - no "extern c" part
Next Topic:debug with stl code freezes
Current Time: Wed Nov 05 21:08:13 EST 2025
Powered by FUDForum. Page generated in 0.03039 seconds
