| RSE don't start after install [message #9045] |
Fri, 18 May 2007 10:45  |
Hi, I need to use RSE to develop software for embedded systems (TM is
needed).
I've tried to install RSE 1.0.1 under Eclipse 3.2 and under 3.2.2 without
any success.
Installation run correctly, but after eclipse restart (I've tried to close
eclipse and run it with "-clean" too), I tring to open RSE Perspective and
I've got follow errors:
1 - Problems opening perspective 'org.eclipse.rse.ui.view.SystemPerspective'
2 - On Remote System sheet the error message is:
Unable to create View: An unexpected exception was"
3 - On Detail the error message is:
Java.lang.NullPointerException
at java.net.InetAddress.lookup(libgcj.so.7rh)
at java.net.InetAddress.getHostName(libgcj.so.7rh)
org.eclipse.rse.core.RSECorePlugin.getLocalMachineName(RSECo rePlugin.java:65)
org.eclipse.rse.internal.model.SystemProfileManager.getDefau ltPrivateSystemProfileName(SystemProfileManager.java:67)
org.eclipse.rse.internal.model.SystemProfileManager.getProfi les(SystemProfileManager.java:534)
org.eclipse.rse.internal.model.SystemProfileManager.getSyste mProfiles(SystemProfileManager.java:160)
org.eclipse.rse.internal.model.SystemProfileManager.getActiv eSystemProfileNames(SystemProfileManager.java:330)
org.eclipse.rse.internal.model.SystemProfileManager.getActiv eSystemProfiles(SystemProfileManager.java:312)
org.eclipse.rse.model.SystemRegistry.getHostPools(SystemRegi stry.java:1604)
at org.eclipse.rse.model.SystemRegistry.getHosts(SystemRegistry .java:1644)
org.eclipse.rse.model.SystemRegistry.getSystemViewRoots(Syst emRegistry.java:251)
org.eclipse.rse.ui.view.SystemViewRootInputAdapter.getChildr en(SystemViewRootInputAdapter.java:126)
org.eclipse.rse.ui.view.SystemViewLabelAndContentProvider.ge tChildren(SystemViewLabelAndContentProvider.java:308)
org.eclipse.rse.ui.view.SystemViewLabelAndContentProvider.ge tElements(SystemViewLabelAndContentProvider.java:328)
org.eclipse.jface.viewers.StructuredViewer.getRawChildren(or g.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( org.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.TreeViewer.getRawChildren(org.ecli pse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChil dren(org.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(org.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(org.eclip se.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.swt.custom.BusyIndicator.showWhile(org.eclipse.s wt.gtk.linux.x86_3.2.2.v3236.jar.so)
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( org.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.TreeViewer.createChildren(org.ecli pse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.AbstractTreeViewer$5.run(org.eclip se.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(org.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(or g.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.ContentViewer.setInput(org.eclipse .jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.viewers.StructuredViewer.setInput(org.ecli pse.jface_3.2.2.M20061214-1200.jar.so)
at org.eclipse.rse.ui.view.SystemView.init(SystemView.java:386)
at org.eclipse.rse.ui.view.SystemView.<init>(SystemView.java:241)
org.eclipse.rse.ui.view.SystemViewPart.createPartControl(Sys temViewPart.java:373)
org.eclipse.ui.internal.ViewReference.createPartHelper(org.e clipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.ViewReference.createPart(org.eclipse .ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(org.e clipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.PartPane.setVisible(org.eclipse.ui.w orkbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.ViewPane.setVisible(org.eclipse.ui.w orkbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(org.eclipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(org.eclipse.ui.workbench_3.2.2.M20070119-0800.ja r.so)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(org.eclipse.ui.workbench_3.2.2.M20070119-0800.jar. so)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(org.eclipse.ui.workbench_3.2.2.M20070119-0 800.jar.so)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(org.eclipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.PartStack.setSelection(org.eclipse.u i.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.PartStack.showPart(org.eclipse.ui.wo rkbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.PartStack.createControl(org.eclipse. ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.PartSashContainer.createControl(org. eclipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.PerspectiveHelper.activate(org.eclip se.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.Perspective.onActivate(org.eclipse.u i.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(org.ecl ipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(org .eclipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.WorkbenchPage.access$12(org.eclipse. ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.WorkbenchPage$12.run(org.eclipse.ui. workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(org.ecli pse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.actions.PerspectiveMenu.run(org.eclipse.ui.wo rkbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.actions.PerspectiveMenu.runOther(org.eclipse. ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.actions.PerspectiveMenu$3.runWithEvent(org.ec lipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(org.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.action.ActionContributionItem.access$2(org .eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(org.eclipse.jface_3.2.2.M20061214-1200.jar.so)
org.eclipse.swt.widgets.EventTable.sendEvent(org.eclipse.swt .gtk.linux.x86_3.2.2.v3236.jar.so)
org.eclipse.swt.widgets.Widget.sendEvent(org.eclipse.swt.gtk .linux.x86_3.2.2.v3236.jar.so)
org.eclipse.swt.widgets.Display.runDeferredEvents(org.eclips e.swt.gtk.linux.x86_3.2.2.v3236.jar.so)
org.eclipse.swt.widgets.Display.readAndDispatch(org.eclipse. swt.gtk.linux.x86_3.2.2.v3236.jar.so)
org.eclipse.ui.internal.Workbench.runEventLoop(org.eclipse.u i.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.Workbench.runUI(org.eclipse.ui.workb ench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(org. eclipse.ui.workbench_3.2.2.M20070119-0800.jar.so)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(org.eclipse. ui.workbench_3.2.2.M20070119-0800.jar.so)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(or g.eclipse.core.runtime_3.2.0.v20060603.jar.so)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(org.eclipse.osgi_3.2.2.R32x_v20070118.jar.so )
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(org.eclipse.osgi_3.2.2.R32x_v20070118.jar.so)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(org.ecli pse.osgi_3.2.2.R32x_v20070118.jar.so)
at java.lang.reflect.Method.invoke(libgcj.so.7rh)
at org.eclipse.core.launcher.Main.invokeFramework(startup.jar.s o)
at org.eclipse.core.launcher.Main.basicRun(startup.jar.so)
at org.eclipse.core.launcher.Main.run(startup.jar.so)
at org.eclipse.core.launcher.Main.main(startup.jar.so)
4 - If I try to create a new project using RSE template I can select the
target (FTP, local, Linux, Windows, ecc..) , but when I click on Next button
the next window don't appears.
Any suggetions ?
Pierluigi
| Re: RSE don't start after install [message #567545 is a reply to message #9045] |
Fri, 18 May 2007 16:57  |
I've solved it. There was a network misconfiguration.
Expecially hostname was different respect that one in /etc/hosts file.
I've found this mistake runnng "hostname" command.
I hope this can help someone.
Pierluigi
"Pierluigi Bucolo" <tea4two@tin.it> ha scritto nel messaggio
news:f2ke44$qil$1@build.eclipse.org...
> needed).
> any success.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> button the next window don't appears.
> Any suggetions ?
> Regards
> Pierluigi
FUDForum. Page generated in 0.08191 seconds
