Home » Archived » BIRT » SpreadsheetML supported by BIRT?
SpreadsheetML supported by BIRT? [message #99239] Wed, 14 December 2005 16:03 Go to next message
Originally posted by: mlorenz.nc.rr.com
This is the XML schema from Microsoft to easily create Excel files (there
is also one for Word).
Does BIRT generate XML reports? (I know 2.0 talks about XML data sources)
Re: SpreadsheetML supported by BIRT? [message #99283 is a reply to message #99239] Wed, 14 December 2005 16:25 Go to previous messageGo to next message
Originally posted by: m.n.com
Do you have good documentation on this? I have searched and found
little. It seems Microsoft provides less info on this than the little
they provide on other things. It seems they treat it like a red-headed
stepchild ("Yes, we do XML") and it probably will go away when they
start using their new XML format.
Mark
> (there is also one for Word).
Re: SpreadsheetML supported by BIRT? [message #99489 is a reply to message #99283] Thu, 15 December 2005 06:19 Go to previous messageGo to next message
> Mark
>> sources)
Also, make sure you read the license!! You can READ but not write!!
This means you probably won't be able to use it in BIRT. Try OpenDoc
instead.
Daz
Re: SpreadsheetML supported by BIRT? [message #99568 is a reply to message #99489] Thu, 15 December 2005 10:59 Go to previous messageGo to next message
I thought I had heard something like that. I wonder if the same will be
true of Microsoft's new format that they are submitting to the
standards. Probably be a different twist.
>> red-headed stepchild ("Yes, we do XML") and it probably will go away
>> when they start using their new XML format.
>> Mark
>>> sources)
> instead.
> Daz
Re: SpreadsheetML supported by BIRT? [message #99806 is a reply to message #99568] Thu, 15 December 2005 12:51 Go to previous messageGo to next message
I'm considering POI-HSSF (http://jakarta.apache.org/poi/hssf/) instead
anyway. I should know better than to trust MS...
Re: SpreadsheetML supported by BIRT? [message #99874 is a reply to message #99239] Thu, 15 December 2005 14:09 Go to previous message
Originally posted by: none.none.none
Birt 2.0 will supposedly be able to export your report data into CSV, which
Excel handles with ease. Just curious... what are you guys needing to do
above & beyond that?
"Mark Lorenz" <mlorenz@nc.rr.com> wrote in message
news:18eaa1de5549fe948c32661a34f64f2c$1@www.eclipse.org...
Previous Topic:Newbie questions --> How to render Report out of JSF Application
Next Topic:DB2 Problem
Current Time: Sat Nov 08 19:24:38 EST 2025
Powered by FUDForum. Page generated in 0.04324 seconds
