Home » Newcomers » Newcomers » 64-bit Linux, RHEL4, unable to start eclipse
64-bit Linux, RHEL4, unable to start eclipse [message #99158] Fri, 02 September 2005 12:50 Go to next message
Originally posted by: nucci.psu.edu
I installed the eclipse SDK 3.1 on my Red Hat EL4 (WS) AMD Opteron powered
linux box. I am using the SUn JRE 1.5 Update 4. When I go to start eclipse
the following error pops in the log and eclipse dies:
!SESSION 2005-09-02 12:45:45.290
-----------------------------------------------eclipse.build Id=I20050627-1435
java.version=1.5.0_01
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 2005-09-02 12:45:46.124
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError:
/home/nucci/proj/eclipse/eclipse/configuration/org.eclipse.o sgi/bundles/15/1/.cp/libswt-pi-gtk-3138.so:
cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751)
(rest of stack deleted)
any thoughts / comments / corrections to what I may have done incorrectly?
I can start eclipse on a 32-bit Intel Xeon machine running RHEL 3 that
uses an older version of the jre.
thanks,
--Jeff
Re: 64-bit Linux, RHEL4, unable to start eclipse [message #99237 is a reply to message #99158] Fri, 02 September 2005 18:15 Go to previous messageGo to next message
Originally posted by: bbiggs.ca.ibm.com
> powered linux box. I am using the SUn JRE 1.5 Update 4. When I go to
> start eclipse the following error pops in the log and eclipse dies:
If you are using a 64-bit JVM, you must get the x86-64 version of
Eclipse. Similarly, if you'd rather use the 32-bit JVM (it is more
stable), then you'll need the 32-bit version of Eclipse.
From your log, you were trying to run the 32-bit version of Eclipse.
For this one, you should also make sure you have the 32-bit version
of the required libraries as well (GTK+ etc).
-Billy
Re: 64-bit Linux, RHEL4, unable to start eclipse [message #101363 is a reply to message #99237] Mon, 12 September 2005 15:56 Go to previous message
> -Billy
Previous Topic:Eclipse3.1-SDK installation suse9.3
Next Topic:Serial Port
Current Time: Fri Oct 24 20:42:21 EDT 2025
Powered by FUDForum. Page generated in 0.08643 seconds
