Home » Eclipse Projects » Equinox » java.lang.OutOfMemoryError: PermGen space
java.lang.OutOfMemoryError: PermGen space [message #98950] Sun, 30 September 2007 10:00 Go to next message
Originally posted by: stepper.sympedia.de
Since I freshly installed the Europa Fall Maintenance release of eclipse
I frequently get the above exception or eclipse simply disappears
without premonition. It's so annoying. After such a crash I always have
to delete all projects from the workspace and import them again. Then I
need to distribute 50 projects into my 6 working sets again.
I have a 1 gig box and have --launcher.XXMaxPermSize 256M in eclipse.ini.
Shouldn't that be enough?
I have only the rcp epp + emf sdk installed.
Please see also my posting to
http://www.eclipse.org/newsportal/article.php?id=21548&g roup=eclipse.tools.jdt#21548
Cheers
/Eike
Re: java.lang.OutOfMemoryError: PermGen space [message #98980 is a reply to message #98950] Sun, 30 September 2007 16:07 Go to previous messageGo to next message
Originally posted by: alex_blewitt.yahoo.com
The --launcher and 256m need to be on separate lines.
Alex.
Re: java.lang.OutOfMemoryError: PermGen space [message #99025 is a reply to message #98980] Mon, 01 October 2007 02:06 Go to previous messageGo to next message
Yes they are. Eclipse.ini is as it came:
-showsplash
org.eclipse.platform
256M
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
Re: java.lang.OutOfMemoryError: PermGen space [message #99040 is a reply to message #99025] Mon, 01 October 2007 04:45 Go to previous messageGo to next message
All I can think is that there is some badly-written plugin that's leaking that you have installed. Unfortunately, it's no easy feat to find out which one.
Alex
Re: java.lang.OutOfMemoryError: PermGen space [message #99056 is a reply to message #99040] Mon, 01 October 2007 07:31 Go to previous messageGo to next message
Cheers
/Eike
Re: java.lang.OutOfMemoryError: PermGen space [message #99481 is a reply to message #99056] Tue, 09 October 2007 12:52 Go to previous messageGo to next message
>> find out which one.
If you're using 3.3.1, maybe it's
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203325
Unfortunately, I fixed my eclipse.ini and still keep getting PermGen
errors, which I'm unable to troubleshoot because I can't enable JMX,
jvmstat or similar tool :-(
HTH,
Daniel Serodio
Re: java.lang.OutOfMemoryError: PermGen space [message #99494 is a reply to message #99481] Tue, 09 October 2007 18:07 Go to previous messageGo to next message
Daniel,
Thank you, I was already aware of that Bugzilla.
I decided to stay with 3.3.0 for a while because I first wanted to hear
that the suggested fix really works so that I don't have to go
upgrade-downgrade cycles again ;-)
Good that I have waited!
Cheers
/Eike
>>> find out which one.
> HTH,
> Daniel Serodio
Re: java.lang.OutOfMemoryError: PermGen space [message #100032 is a reply to message #99494] Thu, 18 October 2007 14:14 Go to previous message
Well this time, the fault was on me :-) I had mispelled the MaxPermGen
parameter (because the "--launcher" syntax is different from the
"-vmargs" one), and Eclipse didn't warn me because of bug 205990.
After I fixed the MaxPermGen parameter, it works. Unfortunately, I still
can't enable JMX or jvmstat.
HTH,
Daniel Serodio
Eike Stepper wrote:
> Daniel,
> Cheers
> /Eike
>>>> find out which one.
>> HTH,
>> Daniel Serodio
Previous Topic:P1 blocker bug with loading of OSGi Extensions
Next Topic:What's contained in "~/.eclipse" ?
Current Time: Sat Nov 08 16:02:17 EST 2025
Powered by FUDForum. Page generated in 0.04681 seconds
