Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] comparison byte[] with Byte[]
[Teneo] comparison byte[] with Byte[] [message #98914] Wed, 10 October 2007 11:35 Go to next message
I am not sure if this can be solved at emf-teneo level or lies with
hibernate.
We have a binary attribute.
In emf core attribute type is EByteArray [byte[]] and in hibernate file
array has byte element type i.e. <element type="byte"/>.
Data is saved and retrieved fine.
But only thing is that when hibernate looks for changes it compares
btye[] with Byte[]. Though contents are same that result in treating it
as dirty i.e. org.hibernate.type.TypeFactory.findDirty() method compares
"currentState" as byte [ ] with "previousState" as Byte[ ].
So everytime data is loaded, this one is always marked dirty.
Is there some way around this?
Thanks.
- Parvez
Re: [Teneo] comparison byte[] with Byte[] [message #99048 is a reply to message #98914] Thu, 11 October 2007 03:05 Go to previous messageGo to next message
Hi Parvez,
Just two ideas:
1) change the type used in emf (I am not sure if this is possible in your case, probably this is
something you already thought of)
2) create your own hibernate usertype which is used to persist this efeature. You can try to find
out which type is used by hibernate (subclass of org.hibernate.type.Type) and override that class
and its isDirty methods.
Your type can then be set in an annotation in the efeature (see hibernate typedef and type annotations).
gr. Martin
PC wrote:
> hibernate.
> Thanks.
> - Parvez
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] comparison byte[] with Byte[] [message #100355 is a reply to message #99048] Tue, 30 October 2007 13:40 Go to previous messageGo to next message
Hi Martin,
That has been resolved by changing array to property i.e.
Earlier it was <array> </array> containing type as <element type="byte"/>
Now changed to property, which is working fine i.e.
<property name="data" lazy="false" insert="true" update="true"
not-null="true" unique="false" type="binary">
<column not-null="false" unique="false"
name="`librarydata_data_id`"/>
</property>
Thanks.
- Parvez
Martin Taal wrote:
> Hi Parvez,
> Just two ideas:
> your case, probably this is something you already thought of)
> efeature. You can try to find out which type is used by hibernate
> (subclass of org.hibernate.type.Type) and override that class and its
> isDirty methods.
> gr. Martin
> PC wrote:
>> hibernate.
>> file array has byte element type i.e. <element type="byte"/>.
>> it as dirty i.e. org.hibernate.type.TypeFactory.findDirty() method
>> compares "currentState" as byte [ ] with "previousState" as Byte[ ].
>> Thanks.
>> - Parvez
Re: [Teneo] comparison byte[] with Byte[] [message #100384 is a reply to message #100355] Wed, 31 October 2007 04:03 Go to previous message
Hi Parvez,
Thanks for the update, good to know that this also works. I will consider this also as a mapping for
byte arrays (maybe driven by an option).
gr. Martin
PC wrote:
> Hi Martin,
> </property>
> Thanks.
> - Parvez
> Martin Taal wrote:
>> Hi Parvez,
>> Just two ideas:
>> isDirty methods.
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> hibernate.
>>> Thanks.
>>> - Parvez
The Netherlands
Re: [Teneo] comparison byte[] with Byte[] [message #609992 is a reply to message #98914] Thu, 11 October 2007 03:05 Go to previous message
Hi Parvez,
Just two ideas:
gr. Martin
PC wrote:
> hibernate.
> Thanks.
> - Parvez
The Netherlands
Re: [Teneo] comparison byte[] with Byte[] [message #610173 is a reply to message #99048] Tue, 30 October 2007 13:40 Go to previous message
Hi Martin,
</property>
Thanks.
- Parvez
Martin Taal wrote:
> Hi Parvez,
> Just two ideas:
> isDirty methods.
> gr. Martin
> PC wrote:
>> hibernate.
>> Thanks.
>> - Parvez
Re: [Teneo] comparison byte[] with Byte[] [message #610177 is a reply to message #100355] Wed, 31 October 2007 04:03 Go to previous message
Hi Parvez,
gr. Martin
PC wrote:
> Hi Martin,
> </property>
> Thanks.
> - Parvez
> Martin Taal wrote:
>> Hi Parvez,
>> Just two ideas:
>> isDirty methods.
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> hibernate.
>>> Thanks.
>>> - Parvez
The Netherlands
Previous Topic:[Teneo]foreign key element in jdo not generated properly?
Next Topic:[Teneo]foreign key element in jdo not generated properly?
Current Time: Sat Jul 26 20:15:22 EDT 2025
Powered by FUDForum. Page generated in 0.04124 seconds
