| showing selected row in TableViewer - bug [message #98736] |
Thu, 17 July 2008 04:09  |
Run snippet and then click to button "generate random input" several
times and you will see that in some case isn't show blue color on
selected row in table. But all others things works well (listeners).
Problem is in RAP 1.1.0 and RAP 1.1.1 .
Rap 1.1 M3 work well in this case.
import java.util.ArrayList;
import java.util.List;
import java.util.Random;
import org.eclipse.jface.viewers.ISelectionChangedListener;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.SelectionChangedEvent;
import org.eclipse.jface.viewers.StructuredSelection;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.ui.part.ViewPart;
public class Snippet extends ViewPart {
private TableViewer tableViewer;
public void createPartControl(Composite parent) {
parent.setLayout(new GridLayout(1, false));
final Button btn = new Button(parent, SWT.PUSH);
btn.setText("generate random input");
btn.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
Random r = new Random();
int itemsCount = r.nextInt(10) + 10;
List<Data> input = new ArrayList<Data>();
for (int i = 0; i < itemsCount; i++) {
input.add(new Data("random item " + r.nextInt(1000)));
tableViewer.setInput(input);
tableViewer.setSelection(new
StructuredSelection(input.get(0)));
final Label label = new Label(parent, SWT.None);
label.setLayoutData(new GridData(GridData.FILL_HORIZONTAL |
GridData.GRAB_HORIZONTAL));
tableViewer = new TableViewer(parent, SWT.None);
tableViewer.getTable().setLayoutData(new
GridData(GridData.FILL_BOTH | GridData.GRAB_HORIZONTAL |
GridData.GRAB_VERTICAL));
tableViewer.setLabelProvider(new LabelProvider());
tableViewer.setContentProvider(new IStructuredContentProvider() {
@SuppressWarnings("unchecked")
public Object[] getElements(Object inputElement) {
return ((List<Data>) inputElement).toArray();
public void dispose() {
//nothing
public void inputChanged(Viewer viewer, Object oldInput,
Object newInput) {
//nothing
tableViewer.addSelectionChangedListener(new
ISelectionChangedListener() {
public void selectionChanged(SelectionChangedEvent event) {
Data data = (Data) ((StructuredSelection)
event.getSelection()).getFirstElement();
label.setText("selected row: " + data);
public void setFocus() {
tableViewer.getTable().setFocus();
private class Data {
private String name;
private Data(String name) {
this.name = name;
public String toString() {
return name;
| Re: showing selected row in TableViewer - bug [message #99110 is a reply to message #98736] |
Mon, 21 July 2008 09:12  |
Originally posted by: rsternberg.innoopract.com
Thanks for the snippet, Michal. I filed this bug:
241530: TableViewer#setSelection( ISelection ) does sometimes not work
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241530
Best regards, Ralf
> @Override
> @Override
> @Override
> @Override
> //nothing
> @Override
> Object newInput) {
> //nothing
> @Override
> @Override
> this.name = name;
> @Override
> return name;
FUDForum. Page generated in 0.04074 seconds
